Missread your question.
Goto program files in the Microchip directory and look for the MPASM Suite.
Make sure that both
C:\PBP
AND
C:\Program Files\Microchip\MPASM Suite
are listed in Windows System Variable>>Path ... and it has to work. You may need to reboot your computer before using it.
Trying that now.
I can use PBP from the command line(I'd really prefer to use IDE), but it uses the PM assembler and if I try to make it use MPASM it gives an error.
EDIT:
I added it to the path and it works, thanks.
