This is my first time using MCUs at all and I read that PIC were fairly easy to use. So I got MPLab and started playing around, followed the tutorials, which I completed.
I decided I wanted to write in a higher level language closer to C, so I decided to try PBP. I can't even complete the demo program it provides in the manual. I'm sure that I'm doing something wrong here, but I have no idea what and I've looked around quite a bit, rather unsuccessfully.
So here is what I have:
I'm using MPLab 8.00
I created a project with PBP as my language toolsuite. I copy and pasted this file(the provided example file). Saved it as basic file, added it as source file and hit build.
' Example program from manual to blink an LED connected to PORTB.0 about once a second
loop: High PORTB.0 ' Turn on LED connected to PORTB.0
Pause 500 ' Delay for .5 seconds
Low PORTB.0 ' Turn off LED connected to PORTB.0
Goto loop ' Go back to loop and blink LED forever
And I get this:
Executing: "C:\PBP\PBPW.EXE" -p18F452 -ampasmwin -oq -z "C:\PBP\Test.BAS"
PICBASIC PRO(TM) Compiler 2.50a, (c) 1998, 2007 microEngineering Labs, Inc.
All Rights Reserved.
ERROR: Unable to execute mpasmwin.BUILD FAILED
I think for some reason it cant find the assembler, I have the assembler defined, see here:
http://s29.photobucket.com/albums/c2...nt=Desktop.jpg
What I need to know is if there is a way/how to Check my path defined under the configuration for the PBP tool set.
