attached is a working piece of code for the 16F628
Code:___________________ ' Temperature, Relative Humidity and Dewpoint ' Processor : 16F628 ' Sensor : SHT1x / SHT7x ' Display : 16x2 '** Pin-Assingments dta VAR PORTB.1 ' Sensor Data clk VAR PORTB.0 ' Sensor Clock '** Constants cmdtr CON %00000011 ' Command "read temperature" cmdhr CON %00000101 ' Command "read humitity" '** Variables result VAR WORD ' RAW Data from Sensor chksum VAR BYTE ' Checksum cmd VAR WORD ' Sensor Command RHlin VAR WORD ' Rel. Humidity (RH) Linear (% *10) RHtc VAR WORD ' Rel. Humidity (RH) temp. compensated (% *10) Temp VAR WORD ' Temperature (°C *100) DP VAR WORD ' Dewpiont (°C *10) '** Temp variables used in div. calculations TempDP VAR WORD Rchk VAR BYTE logEW VAR WORD sign VAR BIT wy VAR WORD wz VAR WORD wj VAR WORD wx VAR WORD i VAR BYTE ix VAR BYTE bt VAR BIT Pause 500 LCDOut $FE,1,"** SHT 11 **" PAUSE 1000 main: GoSub init cmd = cmdtr GoSub readsensor Temp=result-3995 GoSub init cmd = cmdhr GoSub readsensor RHlin=(26542-(54722**result+result))**result-40 ' RH linear RHtc=655+(result*5)+(result**15917) RHtc=(RHtc**(Temp/10+2480))-(RHtc**2730)+RHlin ' RH temp. compensated GoSub dewpoint LCDOut $FE,$80," ",$DF,"C"," ",$25,"RH"," DP " LCDOut $FE,$C0,DEC2 (TEMP/100),".",DEC1 (temp/10)," ",DEC2 RHTC/10,".",DEC1 RHTC," ",DEC2 ABS DP/10,".",DEC1 ABS dp sleep 10 GoTo main '** Init Sensor init: High dta Low clk For i=1 to 10 High clk Pause 1 Low clk Pause 1 Next i Call tstart Return '** start transfer tstart: High clk Pause 1 Low dta Pause 1 Low clk Pause 1 High clk Pause 1 High dta Pause 1 Low clk Return '** get Data from Sensor readsensor: GoSub tstart GoSub WaitSensor ShiftOut dta,clk,1,[cmd\8] ' send command Input dta ' wait acknowledge Low clk While dta=1 Wend PulsOut clk,10 ' send ack While dta=0 Wend While dta=1 ' wait for conversion to complete Wend Low clk ShiftIn dta,clk,0,[result.highbyte\8] ' get first byte Low dta PulsOut clk,10 ' send ack ShiftIn dta,clk,0,[result.lowbyte\8] ' get second byte Low dta PulsOut clk,10 ' send ack ShiftIn dta,clk,0,[chksum\8] ' get third byte (checksum) High dta PulsOut clk,10 ' send ack Input dta ' End of Transmission Input clk Return '** Dewpoint Calculation ' See: SENSIRION Application Note "Dewpoint Calculation" ' logEW = (0.66077+7.5*T/(237.3+T)+(log(RH)-2) ' DP = ((0.66077-logEW)*237.3)/(logEW-8.16077) DewPoint: TempDP=Temp/10 logEW=6608 sign=TempDP.bit15 wz=ABS TempDP wx=(7*wz)+(wz/2) wy=2373+wz wj=wx/wy For ix=15 to 0 step -1 wx=(wx//wy)<<1 wz.bit0(ix)=wx/wy Next wx=(-sign^((wj*10000)+(wz**10000)))+sign logEW=wx+logEW wx=RHtc wj=(NCD wx) - 1 wx=wx<<(15-wj) wz=0 For ix=14 to 0 step -1 wy=wx**wx wz.bit0(ix)=wy.bit15 bt=~wy.bit15 wx=(wy<<bt)+(bt && wx.bit15) Next wx=((wj*4000)**49321)+(wz**6021) logEW=wx+logEW-30000 sign=logEW.bit15 logEW=(-sign^(((ABS logEW)+2)/4))+sign wx=1652-logEW sign=~wx.bit15 wx=ABS wx wy=20402-logEW wj=wx/wy For ix=15 to 0 step -1 wx=(wx//wy)<<1 wz.bit0(ix)=wx/wy Next DP=((23730**wz)+5)/10 DP=(-sign^DP)+sign Return WaitSensor: result=4096 Loop: result=result-1 IF dta && result.bit11 Then Loop Return End ___________________
Ralph
