Sensirion SHT11 with a PIC16F628-20
View Poll Results: Have I included enough relevant material to make the problem clear?
Voters
1. You may not vote on this poll
  • YES. I see what you mean
    0 0%
  • COULD BE BETTER: Kind of understand what your trying to say
    1 100.00%
  • NO: What the heck are you talking about
    0 0%
Results 1 to 27 of 27
    Nov 2004
    malawi
    Default Need help also
    hi! iam also working SHT11 project with PIC16F877 display with LCD, itry Ralph source code but, only **SHT 11** display no sensor reading ,can someone email source code to me? [email protected]
    thanks
    Aug 2005
    Ontario, Canada
    Thumbs up Missing part of code SHT11
    For anyone trying to get this first off, add wx=wy<< bt+(bt & wx.bit15)
    instead of the truncated part Christian had indicated.
    (nice work on the code Ralph)
    This works fine on a PIC16F876A 20mhz using portc.3 and portc.4
    I can see why Ralph had problems with it not posting properly. I had to
    put in a space before the first bt to see it properly as without the space
    it was truncating my reply too. Anyone else have a problem posting code
    like this?
    (helps to look at the preview)
    Hope this helps someone.
    Ron
    Mar 2007
    Unhappy Please help me ??????
    I have been trying to get this code to work for the last week,A friend and i have both recived samples and have been unable to get the project going after overcoming the first compile error it seems that the device wont respond and it just hangs in the readsensor routine, Could yoiu please post the working picbasic pro or email it to me at [email protected].
    it seems that if i force data line to go low by shorting to ground the code execution continues and outputs repative numbers.
    There is a misplaced next could you please clarafy where this is ment to go
    regards Evolution
    Angry Sometimes I feel tired ... but why ????
    Mar 2007
    Angry Gee Thanx
    Why bother running the forum im sure all of us have no worries translating the cryptic data presented in these sheets and great bs2 code????? pbp
    Question
    Quote Originally Posted by Evolution View Post
    Sorry ... but could you be more explicit ... difficulties to fully understand your answer.
    Mar 2007
    Red face The SHT11 Issue
    First of all i had the code error where the example was missing (wx=(wy< Next <<<<---------) after replacing this with the example above it seems that code execution halts on waiting for initalisation command(data pulled low) and nothing will happen untill i manualy ground the pin temproraly oncei do this it outputs repeating numbers in an unordly fashion
    i am using picbasic pro 2.44 but can also code in assembly the selected mcu is a pic16f628 a running at 4mhz internal osc
    Would greatly appreciate any help you could provide i had a look at the bs2 code you pointed out and will try to convert it to picbasic
  1. Watchdog Timers
    Last Post: - 27th August 2014, 18:03
  2. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 20:07
  3. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 03:19
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
  5. Serout PIC16F628 to PC R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 19th June 2005, 00:29
