Sensirion SHT11 with a PIC16F628-20
View Poll Results: Have I included enough relevant material to make the problem clear?
Voters
1. You may not vote on this poll
  • YES. I see what you mean
    0 0%
  • COULD BE BETTER: Kind of understand what your trying to say
    1 100.00%
  • NO: What the heck are you talking about
    0 0%
Results 1 to 27 of 27
    Sep 2005
    Campbell, CA
    Default Re: Sensirion SHT11 with a PIC16F628-20
    I have successfully used the code below with an 18F2321.
    It should work the same with a 16F part.
    I found it somewhere here on the forum, and it works great.
    '------------------ Read SHT71 Temperature / Humidity Sensor -------------------
    ReadSHT71:
        SHTCommand = ReadTemp
        gosub Initialize
        GOSUB TransmissionStart
        GOSUB IssueCMD
        gosub ConvertToCelsius
        SHTCommand = ReadHumidity
        gosub Initialize
        GOSUB IssueCmd
        gosub ConvertToRH
        TEMPC = (TempC/100) - 2
        TempC.7 = SignC
        RHTempComp = RHTempComp/100
    '--------------------- Calculate Relative Humidity -----------------------------
    ConvertToRH:
    ' 12 Bit    RHLinear = -4 + 0.0405 * DataOutput -0.0000028 * DataOutput^2
        w = 405 * RawData
        w = div32 100
        x = RawData * RawData
        x = div32 1000
        x = x * 28
        x = div32 100
        RHLinear = w - x - 400
    '---------- Calculate Relative Humidity with Temperature Compensation ----------
        w = (8 * RawData + 1000) / 10
          IF SignC = 0 THEN      ' "+"
            if tempC > 2500 then
                x = (tempC - 2500) * w
                x = div32 100
                RHTempComp = RHLinear + x / 100
                x = (2500 - tempc) * w
                x = div32 100
                RHTempComp = RHLinear - x / 100
            x = (2500 + tempC) * w
            x = div32 10000
    '---------------------------- Initialize the Sensor ----------------------------
    Initialize:
        high DataPin                   ; Start condition
        low clk
        for i = 1 to 10
            high clk
            pause 1
            low clk
            pause 1
        next i                          ; Leaves clock low
    '---------------------------- Get Data from Sensor -----------------------------
    IssueCmd:
        Pause 2
        low Clk
        shiftout DataPin,clk,1,[SHTCommand\8]       ' Send command byte
        input DataPin
    WaitForAck:
         x = 0
    WaitForAck2:
        IF DataPin = 1 THEN
          x = x + 1
          if x = 0 then goto NoAck
          Pauseus 2
          GotoWaitForAck2
        High Clk
        pause 10                                    ' Issue ACK from PIC
        low clk
        pause 10                                    ' Make certain we don't move forward on a glitch
        WHILE DataPin:WEND
        shiftin DataPin,clk,0,[RawData.byte1\8]     ' Get the first byte, 8 bits
        low DataPin
        HIGH Clk
        PAUSE 10
        LOW Clk
        pulsout clk,10                              ' Send NACK
        shiftin DataPin,clk,0,[RawData.byte0\8]     ' Get the second byte, 8 bits
        low DataPin
        pulsout clk,10                              ' Send acknowledge
        shiftin DataPin,clk,0,[crc\8]               ' Get third byte, 8 bits, CRC
        high DataPin
        input DataPin                               ' End of Transmission
        input clk
        ERR = 0
    NoAck:
        ERR = 1
    '---------------------------- Start Transfer -----------------------------------
    TransmissionStart:
        HIGH DataPin      ; Make sure it is high
        Pause 1
        high clk
        pause 1
        low DataPin
        pause 1
        low clk
        pause 1
        high clk
        pause 1
        high DataPin
        pause 1
        low clk
    '----------------------------- Raw Data to Degrees C ---------------------------
    ConvertToCelsius:
    ' 14 Bit    Temperature = -40.00 + 0.01 * DataOutout
        if RawData => 4000 then
            tempC = RawData - 4000
            SignC = 0
            tempC = 4000 - RawData         ; Negative Temps
            SignC = 1
    Charles Linquist
    Apr 2011
    what software you use as a compiler?
    pardon my beginner programing and
    program how to display the sensor readings of temperature and humidity SHT11 to 16bit and two-line LCD ....
    thanks very much
  1. Watchdog Timers
    Last Post: - 27th August 2014, 18:03
  2. INT2 anomaly in DT_INTS-18??
    Last Post: - 17th February 2010, 20:07
  3. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 03:19
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 01:31
  5. Serout PIC16F628 to PC R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 19th June 2005, 00:29
