4017 counter and pic
Results 1 to 2 of 2
    Maybe not 0 as default, but for sure 0 after a reset. Look at the Functional Truth Table (page 2 of the following PDF).
    http://www.onsemi.com/pub_link/Colla...MC14017B-D.PDF
    Clock Enable can be connected to Vss all the time, so the output will shift at each clock rising edge.
    What i would do is to connect Reset and Clock on the PIC, and Clock enable to Vss.
    Check PDF page 3, Output Drive current... not a good idea to use this chip as is to drive LEDs... maybe you have high efficiency ones? Spec might be different from brand to brand though... worth a look.
  1. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 21:06
  2. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  3. How to set TMRO & TMR3 as Counter?.
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 18th May 2007, 09:52
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 07:20
