contorlling servo motor
Results 1 to 11 of 11
    Exclamation
    Hi, Henrik
    No,NO ...PULSOUT is one of the XTAL freq dependant commands ... There's NO DEFINE to get rid of that !!!
    @ 20Mhz, the result will simply be 20/4 times that @ 4Mhz ...
    Alain,
    Yep, you're right! I didn't remeber correctly..... :-(
    To quote the docs:
    If a 4MHz oscillator is used, the Period of the generated pulse will be in 10us increments. If a 20MHz oscillator is used, Period will have a 2us resolution. Defining an OSC value has no effect on PULSOUT. The resolution always changes with the actual oscillator speed.
    Sorry for the confusion!
    May 2008
    so do u all mean this:
    When a 20MHz crystal is used, the time
    interval of PULSOUT is in units of 2us. For example, the following PicBasic statement generates a pulse with a width of 1.3 ms from bit 0 of PortB (1.3 ms = 1300us and 1300/2 = 650):
    PULSOUT 0, 650
    izzit like that?? can u all give sample codes, so i can see clearly..
    thanks
    Hi, Shirleyzzzzzzzz ...
    that's it !
    Find here an application ...
    '*  Name    : Glow Driver with Fail Safe - 1                    *
    '*  Author  : Ironsides                                         *
    '*  Notice  : Copyright (c) 2004 C                              *
    '*  Date    : 24 Feb 2004                                       *
    '*  Notes   : Turns on glow driver to glow plug at low throttle *
    '*            If sigal is lost for 5 secs, engine is killed and *
    '*            glow power turned off                             *
    '*          ; An N Channel MOSFET is needed to carry the current*
    '*          ; See the circuit diagram for details               *
    '*  Caution : Should have a safety cut off switch in the pits   *
    '*          : For PIC 12F675                                    *
    ;The 12F675 has both analog converters and analog comparators.
    ;You must disable both to use the I/O pins for digital functions.
    ;In addition, the register that controls the analog converters
    ;has been named ANSEL, and it has a different format that the ADCON1
    ;register found on most PICmicro MCUs
    PCON.3 = 1
    ANSEL = 0               ;needed as as above
    CMCON = 7
          errorlevel  -302  ; Suppress message 302
          bcf   STATUS,RP0  ; Bank 0
          clrf  GPIO        ; Init GPIO
          movlw 07h         ; Set GP<2:0> to
          movwf CMCON       ;   digital IO
          bsf   STATUS,RP0  ; Bank 1
          clrf  ANSEL       ; Digital IO
          movlw 0Ch         ; Set GP<3:2> as inputs
          movwf TRISIO      ; and set up GP<5:4,1:0> as outputs
    endasm
    DEFINE OSC4             ;sets up 4 meg internal oscillator
    THROTTLE VAR GPIO.1     ;Outputs to throttle servo                    - Pin 6
    GLOW     VAR GPIO.2     ;Output to MOSFET driving glow driver         - Pin 5
    RADIO    VAR GPIO.3     ;Input from receiver                          - Pin 4
    TEST     VAR WORD       ; Used to test for loss of signal
    P        VAR WORD       ; This stores the PULSIN value
    N        VAR WORD       ; Loop counter
    TEST = 0
    RX:                     ; This is where we wait for a signal from the Tx
    PULSIN RADIO,1,P        ; With 4 meg oscillator, PULSIN measures at 10 millisecs
    IF (P < 50) and (test = 0) then GOsub LOS ; Loss of signal
    PULSIN RADIO,1,P        ; Check to see if signal re-established
    if (P < 50) and (test = 1) then goto kill_glow
                            ; There is loss of signal - kill the engine
    IF (P > 100)  and (P < 130) THEN GOSUB SW_ON       ; Turn on glow
    IF (P > 130)                THEN GOSUB SW_OFF      ; Turn off glow
    goto RX
    SW_ON:
        HIGH GLOW                 ; This tunrs on the glow signal on Pin 5
        PULSOUT THROTTLE, p       ; send the normal signal to the throttle servo
    SW_OFF:
        LOW GLOW                  ; This turns off the glow signal on Pin 5
    LOS:
         TEST = 1                 ; Set for loss of signal
         For N = 1 to 5
         Pause 1000               ; one second  - 5 secs total
         NEXT n
    KILL_GLOW:
         low glow               ; Turn off the glow plug
    KILL_ENGINE:
         PULSOUT throttle, 101  ; Kill engine  - adjust this value to get the
                                ; carb closed to prevent dirt from entering
         pause 50               ; Needs a pause to stop servo hum
         goto KILL_ENGINE       ; Keep in loop to stop spurious signals
    END                         ;Terminate the program
    May 2008
    so the code that i write, izzit correct....i mean pulseout code for 20MHz???
    Cool
    that's it !
    May 2008
    thank you so much....
  1. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 19:45
  2. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  3. how to change servo motor PWM
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 21st September 2008, 07:02
  4. Replies: 10
    Last Post: - 26th May 2008, 07:00
  5. information on how to make servo motor
    By rod27cn in forum mel PIC BASIC Pro
    Last Post: - 17th December 2006, 11:59
