contorlling servo motor
Results 1 to 11 of 11
    May 2008
    Default contorlling servo motor
    hi
    i'm using PIC16F877A for my line follower. there will be a robotic arm too... i'm decided to use picbasic as it is easier to control the servo.
    for the line follower, i'm planning to use 20MHz osc. so, izzit possible for my robotic arm.
    this is info that i know:
    PIC16F877A microcontroller is used and the microcontroller is operated
    with a 4 MHz crystal. The pulse required to operate a servomotor can very easily be obtained using the PULSOUT
    statement of the PicBasic and PicBasic Pro compilers. When a 4 MHz crystal is used, the time
    interval of PULSOUT is in units of 10s. For example, the following PicBasic statement generates
    a pulse with a width of 1.3 ms from bit 0 of PortB (1.3 ms = 1300us and 1300/10 = 130):
    PULSOUT 0, 130
    With an 20Mhz OSC, the resolution of PULSOUT is??.
    IIRC the resolution of the pulsout command is 10uS no matter what osciallator frequency you are using -as long as you let PBP know what frequency you are using.
    So if you tell PBP that you are using a 10Mhz clock but in reallity it's 20MHz you'll get 6.5ms instead of 13 with Pulsout 0,130. Just remeber that all timing sensetive commands, like Pause, Serin/out, Pulsin etc also is affacted the same way.
    Exclamation
    Hi, Henrik
    No,NO ...PULSOUT is one of the XTAL freq dependant commands ... There's NO DEFINE to get rid of that !!!
    @ 20Mhz, the result will simply be 20/4 times that @ 4Mhz ...
    Alain,
    Yep, you're right! I didn't remeber correctly..... :-(
    To quote the docs:
    If a 4MHz oscillator is used, the Period of the generated pulse will be in 10us increments. If a 20MHz oscillator is used, Period will have a 2us resolution. Defining an OSC value has no effect on PULSOUT. The resolution always changes with the actual oscillator speed.
    Sorry for the confusion!
    May 2008
    so do u all mean this:
    When a 20MHz crystal is used, the time
    interval of PULSOUT is in units of 2us. For example, the following PicBasic statement generates a pulse with a width of 1.3 ms from bit 0 of PortB (1.3 ms = 1300us and 1300/2 = 650):
    PULSOUT 0, 650
    izzit like that?? can u all give sample codes, so i can see clearly..
    thanks
    Hi, Shirleyzzzzzzzz ...
    that's it !
    Find here an application ...
    '*  Name    : Glow Driver with Fail Safe - 1                    *
    '*  Author  : Ironsides                                         *
    '*  Notice  : Copyright (c) 2004 C                              *
    '*  Date    : 24 Feb 2004                                       *
    '*  Notes   : Turns on glow driver to glow plug at low throttle *
    '*            If sigal is lost for 5 secs, engine is killed and *
    '*            glow power turned off                             *
    '*          ; An N Channel MOSFET is needed to carry the current*
    '*          ; See the circuit diagram for details               *
    '*  Caution : Should have a safety cut off switch in the pits   *
    '*          : For PIC 12F675                                    *
    ;The 12F675 has both analog converters and analog comparators.
    ;You must disable both to use the I/O pins for digital functions.
    ;In addition, the register that controls the analog converters
    ;has been named ANSEL, and it has a different format that the ADCON1
    ;register found on most PICmicro MCUs
    PCON.3 = 1
    ANSEL = 0               ;needed as as above
    CMCON = 7
          errorlevel  -302  ; Suppress message 302
          bcf   STATUS,RP0  ; Bank 0
          clrf  GPIO        ; Init GPIO
          movlw 07h         ; Set GP<2:0> to
          movwf CMCON       ;   digital IO
          bsf   STATUS,RP0  ; Bank 1
          clrf  ANSEL       ; Digital IO
          movlw 0Ch         ; Set GP<3:2> as inputs
          movwf TRISIO      ; and set up GP<5:4,1:0> as outputs
    endasm
    DEFINE OSC4             ;sets up 4 meg internal oscillator
    THROTTLE VAR GPIO.1     ;Outputs to throttle servo                    - Pin 6
    GLOW     VAR GPIO.2     ;Output to MOSFET driving glow driver         - Pin 5
    RADIO    VAR GPIO.3     ;Input from receiver                          - Pin 4
    TEST     VAR WORD       ; Used to test for loss of signal
    P        VAR WORD       ; This stores the PULSIN value
    N        VAR WORD       ; Loop counter
    TEST = 0
    RX:                     ; This is where we wait for a signal from the Tx
    PULSIN RADIO,1,P        ; With 4 meg oscillator, PULSIN measures at 10 millisecs
    IF (P < 50) and (test = 0) then GOsub LOS ; Loss of signal
    PULSIN RADIO,1,P        ; Check to see if signal re-established
    if (P < 50) and (test = 1) then goto kill_glow
                            ; There is loss of signal - kill the engine
    IF (P > 100)  and (P < 130) THEN GOSUB SW_ON       ; Turn on glow
    IF (P > 130)                THEN GOSUB SW_OFF      ; Turn off glow
    goto RX
    SW_ON:
        HIGH GLOW                 ; This tunrs on the glow signal on Pin 5
        PULSOUT THROTTLE, p       ; send the normal signal to the throttle servo
    SW_OFF:
        LOW GLOW                  ; This turns off the glow signal on Pin 5
    LOS:
         TEST = 1                 ; Set for loss of signal
         For N = 1 to 5
         Pause 1000               ; one second  - 5 secs total
         NEXT n
    KILL_GLOW:
         low glow               ; Turn off the glow plug
    KILL_ENGINE:
         PULSOUT throttle, 101  ; Kill engine  - adjust this value to get the
                                ; carb closed to prevent dirt from entering
         pause 50               ; Needs a pause to stop servo hum
         goto KILL_ENGINE       ; Keep in loop to stop spurious signals
    END                         ;Terminate the program
  1. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 19:45
  2. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  3. how to change servo motor PWM
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 21st September 2008, 07:02
  4. Replies: 10
    Last Post: - 26th May 2008, 07:00
  5. information on how to make servo motor
    By rod27cn in forum mel PIC BASIC Pro
    Last Post: - 17th December 2006, 11:59
