problems working with 24C512
Results 1 to 12 of 12
    Apr 2006
    Dear jerson and mister e
    i have rechecked my connections, they are correct. I dont know where is the problem. I have even grounded WP which i havent done before. One more technical aspect that i want to tell you that i have connect WP and A0 and A1 directly to ground i.e. no pull down resistors. IS this making the problem. If any one of you have a working circuit of 24C512 with PIC, please send it so that i can rechecked my connections. Please send me coding as well.
    LETS MOVE TOWARDS SOMETHING PRACTICAL---
    Quote Originally Posted by shaiqbashir View Post
    Pull DOWN resistors? Don't remember anything about Pull DOWN resistors.
    The '512 datasheet I've got has a fairly good schematic. What's your datasheet say?
    Not asking for much eh?
    Bombay, India
    Are you sure your PIC is working? Any test pins that you can blink / toggle to make sure ? I think you have all the coding right including the pin config. I doubt your watchdog / brownout is killing the code execution. This can be ruled out if you can blink a test pin every time you read
    Oct 2003
    holland
    Dear all,
    If you read the datasheet of a 24C512 then you wil see this:
    "device address,first word address,second word address,data"
    so your line
    EWrite:
    I2CWRITE SDA,SCL,%10100000,Addr,[E_ByteOut]
    is not correct
    it must be
    EWrite:
    I2CWRITE SDA,SCL,%10100000,Addr1,[Addr2,E_ByteOut]
    the same for I2CREAD
    Don't forget to mark the read bit.
    mmm... not sure as the address is a WORD here and PBP handle the WORD variable for address. It always worked for me with the EEPROM i used, i've never use the C512, but C1024.
    If by FIRST they mean Most Significant, it has to work, unless, yes you're in a kind of trouble... but this said, if you read the same way you write, you shouldn't have any problem huh?
    For no reason, i stick to a swap of SDA & SCL pin idea and 1.8-4.7K pull-up on both pins.
    Apr 2006
    thanks for your help
    mat jensson you have raised a nice point here. I have tried almost every possibility in my coding as well as in my connections, but its not working at all. Please explain me your idea,
    i mean what do u mean by marking the read bit? and how can i specify two addresses, can u explain me a bit.
    One more thing that i want to share with u all. I get different numbers as output when i connect SDA SCL on different ports.
    when i have
    SDA = portB.1
    SCL= portB.0
    output= 2
    SDA = portD.1
    SCL= portD.0
    output= 2
    SDA = portC.1
    SCL= portC.0
    output= 8
    I just couldnt get it.
    Shaiq Bashir
    Make sure you have A0,A1,A2 on your EEPROM at ground.
    Make these few changes to your existing code.
    CNTRL VAR BYTE ' added for control byte
    CNTRL = %10100000 ' value of control byte
    EWrite:
    I2CWRITE SDA,SCL,CNTRL,Addr,[E_ByteOut] ' Write out the byte
    Pause 10 ' Delay 10ms after each write
    ERead:
    I2CREAD SDA,SCL,CNTRL,Addr,[E_ByteIn] ' Read in the byte
    Does this work?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    For the really last time, i'm still sure your SDA/SCL are reverted and/or you don't have the right Pull-Up resistors on SDA & SCL, and i also endorse the A<2:0> setting.
    OK why i stick to it ?
    1. Because i already used something like that in one of my Radio Decode Dongle to confirm the end-user haven't swap the SDA/SCL line when reading in circuit the target I2C EEprom inside the radio.
    2. Let's say i use a at24c1024 here with the following...
            CONT    CON %10100000
            ADDR    VAR WORD
            ByteA   VAR BYTE
            SDA     var PORTC.4
            SCL     var PORTC.3
            PAUSE   500
    Start:
            for addr = 0 to 10
                    ByteA=ADDR.LOWBYTE
                    I2CWRITE SDA,SCL,CONT,ADDR,[ByteA]
                    PAUSE 20
                    NEXT
            FOR ADDR=0 TO 10
                    I2CREAD SDA,SCL,CONT,ADDR,[ByteA]
                    HSEROUT ["ADDR=", DEC ADDR,_
                             "   ByteA=", DEC ByteA,13,10]
                    NEXT
    I got the expected..
    ADDR=0   ByteA=0
    ADDR=1   ByteA=1
    ADDR=2   ByteA=2
    ADDR=3   ByteA=3
    ADDR=4   ByteA=4
    ADDR=5   ByteA=5
    ADDR=6   ByteA=6
    ADDR=7   ByteA=7
    ADDR=8   ByteA=8
    ADDR=9   ByteA=9
    ADDR=10   ByteA=10
    But now if in my code i swap the SDA, SCL definition to...
            SDA     var PORTC.3
            SCL     var PORTC.4
    i got...
    ADDR=0   ByteA=8
    ADDR=1   ByteA=8
    ADDR=2   ByteA=8
    ADDR=3   ByteA=8
    ADDR=4   ByteA=8
    ADDR=5   ByteA=8
    ADDR=6   ByteA=8
    ADDR=7   ByteA=8
    ADDR=8   ByteA=8
    ADDR=9   ByteA=8
    ADDR=10   ByteA=8
    Amazing how close to your problem it is huh?
    Let's do it much funky now... let's totally remove the EEPROM from the circuit. With the pull-up installed i still have all those 8, without pull-up i got all 0.
    Now, with the right code, but the EEPROM have the wrong A<2:0> setting...
    i got all 16, reverted... all 8.
    Enjoy!
  1. PIC30f4012 Problems
    By Insane in forum mel PIC BASIC
    Last Post: - 18th June 2010, 07:16
  2. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 03:36
  3. lcd menu problems
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 19:00
  4. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 09:03
  5. Why is this so hard? HSEROUT problems.
    By groston in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 13:01
