problems working with 24C512
Results 1 to 12 of 12
Threaded View
  1. #11
    For the really last time, i'm still sure your SDA/SCL are reverted and/or you don't have the right Pull-Up resistors on SDA & SCL, and i also endorse the A<2:0> setting.
    OK why i stick to it ?
    1. Because i already used something like that in one of my Radio Decode Dongle to confirm the end-user haven't swap the SDA/SCL line when reading in circuit the target I2C EEprom inside the radio.
    2. Let's say i use a at24c1024 here with the following...
            CONT    CON %10100000
            ADDR    VAR WORD
            ByteA   VAR BYTE
            SDA     var PORTC.4
            SCL     var PORTC.3
            PAUSE   500
    Start:
            for addr = 0 to 10
                    ByteA=ADDR.LOWBYTE
                    I2CWRITE SDA,SCL,CONT,ADDR,[ByteA]
                    PAUSE 20
                    NEXT
            FOR ADDR=0 TO 10
                    I2CREAD SDA,SCL,CONT,ADDR,[ByteA]
                    HSEROUT ["ADDR=", DEC ADDR,_
                             "   ByteA=", DEC ByteA,13,10]
                    NEXT
    I got the expected..
    ADDR=0   ByteA=0
    ADDR=1   ByteA=1
    ADDR=2   ByteA=2
    ADDR=3   ByteA=3
    ADDR=4   ByteA=4
    ADDR=5   ByteA=5
    ADDR=6   ByteA=6
    ADDR=7   ByteA=7
    ADDR=8   ByteA=8
    ADDR=9   ByteA=9
    ADDR=10   ByteA=10
    But now if in my code i swap the SDA, SCL definition to...
            SDA     var PORTC.3
            SCL     var PORTC.4
    i got...
    ADDR=0   ByteA=8
    ADDR=1   ByteA=8
    ADDR=2   ByteA=8
    ADDR=3   ByteA=8
    ADDR=4   ByteA=8
    ADDR=5   ByteA=8
    ADDR=6   ByteA=8
    ADDR=7   ByteA=8
    ADDR=8   ByteA=8
    ADDR=9   ByteA=8
    ADDR=10   ByteA=8
    Amazing how close to your problem it is huh?
    Let's do it much funky now... let's totally remove the EEPROM from the circuit. With the pull-up installed i still have all those 8, without pull-up i got all 0.
    Now, with the right code, but the EEPROM have the wrong A<2:0> setting...
    i got all 16, reverted... all 8.
    Enjoy!
  1. PIC30f4012 Problems
    By Insane in forum mel PIC BASIC
    Last Post: - 18th June 2010, 08:16
  2. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 04:36
  3. lcd menu problems
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 20:00
  4. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 10:03
  5. Why is this so hard? HSEROUT problems.
    By groston in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 14:01
