problems working with 24C512
Results 1 to 12 of 12
    Apr 2006
    Exclamation problems working with 24C512
    Dear fellows
    Im facing problems working with 24C512 eeprom. Im posting here my coding. IN simulation, it seems to work fine on proteus but in the real it doesnt. Herez my coding.
    Include "Modedefs.Bas"
    ' ** Setup the Crystal Frequency, in Mhz **
    Define OSC 4 ' Set Xtal Frequency
    ' ** Setup the I2C configuration **
    Define I2C_SCLOUT 1 ' No need for the pullup resistor on the SCL pin
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTC
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 0
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTC
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 1
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 8
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 50
    ' ** Declare the Variables **
    SCL Var PortD.0 ' I2C data pin
    SDA Var PortD.1 ' I2C clock pin
    Addr Var Word ' 16-bit memory address within the Eeprom
    E_ByteOut Var Byte ' Data byte to be written to the Eeprom
    E_ByteIn Var Byte ' Data byte read from the Eeprom
    x var byte
    ' ** The main program starts here **
    ' Write the string, "HELLO WORLD" into the first 11 address's of the Eeprom
    For Addr=0 To 10 ' Create a loop of 11
    Lookup Addr,[1,255,222,134,10,1,13,19,10,99,219],E_ByteOut' Build up the string
    Gosub EWrite ' Write the byte to the Eeprom
    Next ' Close the Loop
    ' Read the first 11 address's within the Eeprom,
    ' and display them on the LCD
    Again:
    lcdout $FE,1, "starting"
    Pause 1000 ' Clear the LCD
    Pause 500 ' Pause for drama
    Gosub ERead ' Read the byte from the Eeprom
    hserout [dec e_bytein,13,10]
    lcdout $FE,1,#E_bytein
    ' Print the characters read in from the eeprom
    Pause 2000 ' Pause inbetween displays, for drama
    Next ' Close the loop
    Goto Again ' Do it forever
    ' ** SUBROUTINES **
    EWrite:
    I2CWRITE SDA,SCL,%10100000,Addr,[E_ByteOut] ' Write out the byte
    Pause 10 ' Delay 10ms after each write
    ERead:
    I2CREAD SDA,SCL,%10100001,Addr,[E_ByteIn] ' Read in the byte
    The problem im facing is this that the LCD displays "starting" and then instead of displaying the values it read from the eeprom, it displays just 2.
    PLease help me what to do here. I have tried addr.highbyte addr.lowbyte, took control as a byte variable. But nothing seems to work here.
    LETS MOVE TOWARDS SOMETHING PRACTICAL---
    Bombay, India
    Maybe you're missing pull-ups on SDA and SCL?
    Not sure if it works without pull-up with this define...
    BUT if you receive always 2, maybe you reverted your SDA, SCL line as well.. who knows?
    Apr 2006
    Dear jerson and mister e
    i have rechecked my connections, they are correct. I dont know where is the problem. I have even grounded WP which i havent done before. One more technical aspect that i want to tell you that i have connect WP and A0 and A1 directly to ground i.e. no pull down resistors. IS this making the problem. If any one of you have a working circuit of 24C512 with PIC, please send it so that i can rechecked my connections. Please send me coding as well.
    Quote Originally Posted by shaiqbashir View Post
    Pull DOWN resistors? Don't remember anything about Pull DOWN resistors.
    The '512 datasheet I've got has a fairly good schematic. What's your datasheet say?
    Not asking for much eh?
    Bombay, India
    Are you sure your PIC is working? Any test pins that you can blink / toggle to make sure ? I think you have all the coding right including the pin config. I doubt your watchdog / brownout is killing the code execution. This can be ruled out if you can blink a test pin every time you read
    Oct 2003
    holland
    Dear all,
    If you read the datasheet of a 24C512 then you wil see this:
    "device address,first word address,second word address,data"
    so your line
    EWrite:
    is not correct
    it must be
    EWrite:
    I2CWRITE SDA,SCL,%10100000,Addr1,[Addr2,E_ByteOut]
    the same for I2CREAD
    Don't forget to mark the read bit.
    mmm... not sure as the address is a WORD here and PBP handle the WORD variable for address. It always worked for me with the EEPROM i used, i've never use the C512, but C1024.
    If by FIRST they mean Most Significant, it has to work, unless, yes you're in a kind of trouble... but this said, if you read the same way you write, you shouldn't have any problem huh?
    For no reason, i stick to a swap of SDA & SCL pin idea and 1.8-4.7K pull-up on both pins.
    Apr 2006
    thanks for your help
    mat jensson you have raised a nice point here. I have tried almost every possibility in my coding as well as in my connections, but its not working at all. Please explain me your idea,
    i mean what do u mean by marking the read bit? and how can i specify two addresses, can u explain me a bit.
    One more thing that i want to share with u all. I get different numbers as output when i connect SDA SCL on different ports.
    when i have
    SDA = portB.1
    SCL= portB.0
    output= 2
    SDA = portD.1
    SCL= portD.0
    output= 2
    SDA = portC.1
    SCL= portC.0
    output= 8
    I just couldnt get it.
    Shaiq Bashir
    Make sure you have A0,A1,A2 on your EEPROM at ground.
    Make these few changes to your existing code.
    CNTRL VAR BYTE ' added for control byte
    CNTRL = %10100000 ' value of control byte
    EWrite:
    I2CWRITE SDA,SCL,CNTRL,Addr,[E_ByteOut] ' Write out the byte
    ERead:
    I2CREAD SDA,SCL,CNTRL,Addr,[E_ByteIn] ' Read in the byte
    Does this work?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    For the really last time, i'm still sure your SDA/SCL are reverted and/or you don't have the right Pull-Up resistors on SDA & SCL, and i also endorse the A<2:0> setting.
    OK why i stick to it ?
    1. Because i already used something like that in one of my Radio Decode Dongle to confirm the end-user haven't swap the SDA/SCL line when reading in circuit the target I2C EEprom inside the radio.
    2. Let's say i use a at24c1024 here with the following...
            CONT    CON %10100000
            ADDR    VAR WORD
            ByteA   VAR BYTE
            SDA     var PORTC.4
            SCL     var PORTC.3
            PAUSE   500
    Start:
            for addr = 0 to 10
                    ByteA=ADDR.LOWBYTE
                    I2CWRITE SDA,SCL,CONT,ADDR,[ByteA]
                    PAUSE 20
                    NEXT
            FOR ADDR=0 TO 10
                    I2CREAD SDA,SCL,CONT,ADDR,[ByteA]
                    HSEROUT ["ADDR=", DEC ADDR,_
                             "   ByteA=", DEC ByteA,13,10]
                    NEXT
    I got the expected..
    ADDR=0   ByteA=0
    ADDR=1   ByteA=1
    ADDR=2   ByteA=2
    ADDR=3   ByteA=3
    ADDR=4   ByteA=4
    ADDR=5   ByteA=5
    ADDR=6   ByteA=6
    ADDR=7   ByteA=7
    ADDR=8   ByteA=8
    ADDR=9   ByteA=9
    ADDR=10   ByteA=10
    But now if in my code i swap the SDA, SCL definition to...
            SDA     var PORTC.3
            SCL     var PORTC.4
    i got...
    ADDR=0   ByteA=8
    ADDR=1   ByteA=8
    ADDR=2   ByteA=8
    ADDR=3   ByteA=8
    ADDR=4   ByteA=8
    ADDR=5   ByteA=8
    ADDR=6   ByteA=8
    ADDR=7   ByteA=8
    ADDR=8   ByteA=8
    ADDR=9   ByteA=8
    ADDR=10   ByteA=8
    Amazing how close to your problem it is huh?
    Let's do it much funky now... let's totally remove the EEPROM from the circuit. With the pull-up installed i still have all those 8, without pull-up i got all 0.
    Now, with the right code, but the EEPROM have the wrong A<2:0> setting...
    i got all 16, reverted... all 8.
    Enjoy!
    Jan 2006
    Istanbul
    Let this be the schematic for reference.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2625&d=1212050571" >
  1. PIC30f4012 Problems
    By Insane in forum mel PIC BASIC
    Last Post: - 18th June 2010, 08:16
  2. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 04:36
  3. lcd menu problems
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 20:00
  4. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 10:03
  5. Why is this so hard? HSEROUT problems.
    By groston in forum mel PIC BASIC Pro
    Last Post: - 6th November 2006, 14:01
