Array Question:
Results 1 to 12 of 12
Thread: Array Question:
    Default Array Question:
    Hello,
    I am trying to get a better understanding of arrays, and have written the code below. I "think"
    it should output the letters "A" through "j" ;however, it outputs A - K. Anyone know why?
    @ __config  _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF  & _BODEN_OFF
    define OSC 20
    include "modedefs.bas"
    LETTERS VAR BYTE
    String var byte[10]
    serout PortB.6,T9600,[254,128,"Loop Check"]
    serout PortB.6,T9600,[$FE,1]
    string[0]= "A"
    string[1]= "B"
    string[2]= "C"
    string[3]= "D"
    STRING[4]= "E"
    STRING[5]= "F"
    STRING[6]= "G"
    STRING[7]= "H"
    STRING[8]= "I"
    STRING[9]= "J"
    loop:
    FOR letters = STRING[0] to STRING[9]
    serout PortB.6,T9600,[254,128,"string is ",(LETTERS)]
    NEXT letters
    goto loop
    Bombay, India
     Your code
    loop:
    NEXT letters
    goto loop
    I think it should be done like this
    for letters = 0 to 9
      serout PortB.6,T9600,[254,128,"string is ",(string[LETTERS])]
    next
    Default YEP, That fixed her . . .
    Hi Jerson, That fixed it all right, still puzzels me as to why the 10 byte array held 11 though, the way I wrote it. . . Thank You, I will ponder this some more . . .
    JS
    Hi Joe,
    What version of PBP are you using?
    Your first version should work just fine. FOR letters = STRING[0] to STRING[9] is essentially
    the same as FOR letters = "A" to "J", which works the same.
    This;
    DEFINE OSC 20
    INCLUDE "modedefs.bas"
    LETTERS VAR BYTE
    String VAR BYTE[10]
    string[0]= "A"
    string[1]= "B"
    string[2]= "C"
    string[3]= "D"
    STRING[4]= "E"
    STRING[5]= "F"
    STRING[6]= "G"
    STRING[7]= "H"
    STRING[8]= "I"
    STRING[9]= "J"
    loop:
         SEROUT PORTC.6,T9600,["string is ",(LETTERS),13,10]
         PAUSE 500
        NEXT letters
        GOTO loop
    Outputs this;
    string is A
    string is B
    string is C
    string is D
    string is E
    string is F
    string is G
    string is H
    string is I
    string is J
    string is A
    string is B
    string is C
    string is D, etc, etc,
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    But where was the "K" coming from???
    I do not get a "K".
    loop:
         PAUSE 500
        NEXT letters
        GOTO loop
    I found it's a weird way... and a bit obscure...i would used
    loop:
        FOR letters = 0 to 9
         SEROUT PORTC.6,T9600,["string is ",STRING[LETTERS],13,10]
         PAUSE 500
        NEXT letters
        GOTO loop
    seems more valuable no?
    Well that and the way Jerson pointed out, would for sure be the proper way to go,
    but it should still work the way he had it originally as long as characters between string[0]
    and string[9] were in order.
    If you had values assigned to individual elements like say;
    string[0]= "A"
    string[1]= "Z"
    string[2]= "P"
    string[3]= "O"
    string[4]= "M"
    string[5]= "H"
    string[6]= "X"
    string[7]= "G"
    string[8]= "W"
    string[9]= "J"
    Then doing it his original way, it wouldn't return the correct values in each element.
    It would still print A,B,C,D,E,F,G,H,I,J.
    Like Dave, I'm kinda curious where that "K" came from?
    -Bruce
    tech at rentron.com
    That was my point... hidden between the lines Unless a simple FOR To Next without array would have worked.
    Edit: seems i missed Jerson's post
    Hidden between what lines? I still do not get it.
    Hi Bruce, Mister_e,Mackracket, . . .
    Yeaaaa . . . Kinda weirded me out too, I was using a 16F628A, and yes I forgot to put CMCON=7 in, but I was not using PortA. It very definately went from A - K,though I expected it to stop with "J". Jerson straightened me out, still I do not know why it went to K. PBP ver 2.5
    Aliens!?!?
    i don't know.. is "read between the line" a common and known expression worldwide?
    FYI, It was between... "seems" and "more valuable"
    well not between any line at all... forget it
    Time for a beer or twelve i guess. now that i can...
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Array Question....please help
    By jmoskalski in forum mel PIC BASIC Pro
    Last Post: - 31st October 2009, 01:29
  4. How to saparate variable to array and GLCD Question
    By pramarn in forum mel PIC BASIC Pro
    Last Post: - 4th October 2006, 03:42
  5. Stupid array question
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 4th September 2006, 16:03
