Bit Banging input to output on PIC16F876A
Results 1 to 13 of 13
    Talking Thats the ticket
    Now that's what I'm screamin... Thanks Mister E. This is all running in an IF/THEN loop.
    So to recap... My syntax should look like this:
    PORTB.6 = PORTA.2 & PORTB.2 ?
    And judging from what I read; At 20MHZ, this thing should keep up with a PWM frequency of 3000 with no problem? That makes sense considering the PWM is hardware driven.
    Mister E = my hero.
    Thanks for your help too Mel.
    And everyone else for contributing.
    I hope this thread helps someone else that might want to multiplex the two PWM outputs to general purpose outputs.
    Bron...
    The less you expect, the more you get.
    Cool Ok so now... to the SIM!
    Now that I'm pretty sure I have the software settled... Has anyone been able to simulate a PIC16F876A with MPLAB's Simulator? What's the trick? I think I have everything set up right, it doesn't complain, but when I run the compile option it opens the PBP editor and then nothing else happens... Anyone?
    Bron
    Ok I did a IDE Compile in PBP(Microcode Studio +) and the simulator started running after I exited manualy from PBP
    For some reason it's stuck in this loop in PBPPIC14.LIB
    CLRWDT? macro
    ifndef NO_CLRWDT
    clrwdt
    hserinloop CLRWDT? ; Keep Watchdog timer clear
    btfss PIR1, RCIF ; Check for char
    goto hserinloop ; Loop till char
    NOLIST
    HSERINX_USED = 1
    Is it looking for the watchdog timer?
    I'll keep playing with the simulator but this isn't my code, it looks like junk PBP added from the PBPPIC14.LIB?
  1. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  2. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
