Need help calculating OSC cap values
Results 1 to 8 of 8
Threaded View
    Perth, Australia
    Default Need help calculating OSC cap values
    I'm building a low power, low speed circuit using a 32.768kHz crystal but i'm not sure what cap values to use with the oscillator.
    Does anyone know how to work out what values to use?
    PIC: 18LF1320
    CRYSTAL:
    Frequency: 32.768kHz
    Frequency tolerance: ±20ppm (@25°C)
    Operating temperature:-10°C to 60°C
    Shunt capacitance:2pf max.
    Load capacitance:12.5pf
    Insulation resistance:500MOhm @ 100VDC
    Drive level:1µW max.
    ESR (Equivalent series resistance):35KOhm
    *edit*: I'm using a 32.768kHz crystal to facilitate accurate clock timing over longer periods, so that's why I ask about the caps because I have read that the wrong value will put the frequency out.
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 04:35
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  4. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 12:46
  5. calculating arc tangent
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 07:29
