toggle or count?
Results 1 to 5 of 5
    Jan 2007
    Houston, TX
    Default toggle or count?
    Simple question...
    I have a TX module I am sending to an RX board.
    I simply want to push a button once to latch a Relay "ON", then push the same button again to turn the relay "OFF".
    Yes my modules are working fine... I just need help with this simple brain teaser.
    I was thinking of adding + 1 to a variable with a initial condition of zero... each time the button is pushed then divide it down to an even or odd number. If odd the relay stays high, if even the relay if off.
    Basically I am making a simple state machine. I should know this but have not messed with state logic in a while.
    Could I use toggle to do this more simply?
    Padawan-78
    skimask's Avatar
    skimask Guest
    Just increment a variable and only pay attention to the LSB of that variable...
    i.e.
    x = x + 1
    if x.0 = 0 then -the variable is an even number
    if x.0 = 1 then -the variable is an odd number
    Jan 2007
    Houston, TX
    Talking
    That makes perfect sence.
    Perhaps in 10 more years I will be ready to apply for work with Lock Head Martin and propel the next Mars vehicle to welll... Mars. Until then, I will press on and keep learning the basics. Thanks again!
    Padawan-78
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by earltyso View Post
    Looks like the boys (and girls) in Pasadena have pretty much got Mars handled for now...as of tonight anyways...
    Maybe you should shoot for something a wee bit farther out
    Wink
    Simple question...
    Hi, Martian
    You also have, using a single BIT :
    IF Condition_true then relay_state = relay_state ^ 1
  1. Toggle command
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 16th December 2011, 03:07
  2. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  3. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  4. TOGGLE code space and ICD
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 17:08
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
