Serout/serin issues, advice required
Results 1 to 10 of 10
    Cambridge UK
    Hi Skimask and Bruce,
    Thanks for the info, I now have my project up and running. The only other changes I had to make apart from the ones already listed, was to change the variables used in the ADC result and PWM output.
    regards Nick
    Default BiPhase modulation beats Manchester 95% of the time.
    If your system loses or gains half a bit time due to noise, clock slip, whatever, then Manchester goes out of sync and stays out for the rest of the message. BiPhase on the other hand is brought back into sync with the arrival of the very next '1' bit. BiPhase does not propagate errors. The code for biphase is virtually identical to manchester. Manchester needs very high accuracy clocks at both ends. BiPhase is much more tolerant of clock differences. The downside of biphase is that the channel needs a somewhat wider bandwidth.
    Search for biphase code in the forum. I have posted on it before.
    HTH
    BrianT
    Cambridge UK
    Hi Brian,
    Thanks for the info, I have just searched biphase and found a couple of posts. How do you encode and decode in laymans terms?
    This is as far as I have got with my rf;
    I can toggle the output of a pic by sending a set of 0's and 1's to balance the data slicer, followed by a data byte. The rf modules I am using are AM and are supplied from RF solutions.
    My next step was the code posted above, the aim of this was to control the speed of a motor using the rf modules and pics. By encoding the adc result and out putting it in the form of pwm.
    Once I had the code working on the breadboard I transfered it to the Tx/Rx, at this moment in time I can control the motor at a 4 meter range, I have not tried any further as I have not had the time. This has all been acheived using the internal clock set at 8meg, I have taken skimasks advice and ordered some crystals to improve the timing errors. Any other improvements I can make would be an advantage.
    Kind regards Nick
    You're code show a Manchester Encoding/Decoding routine... so it has to work. Maybe not a bad idea to have a bigger $AA preamble before sending your data.
    Crystal are always welcome....
    You could still waste quite of your time and try to fine tune the internal one with OSCTUNE register.
  1. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 28th May 2009, 00:03
  2. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 17:37
  3. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:21
  4. bankA issues
    Last Post: - 23rd July 2006, 09:43
  5. Advice on PS/2 Scan Codes
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 13th January 2006, 19:05
