Solved: notes on annoying little issues
Results 1 to 7 of 7
Threaded View
  1. #7
    Here's some rubbish English explanation that comes to mind, based on my own experience.
    PBP manual... good enough?
    I tend to say yes, it's not an Microcontroller lessons, not either an electronic basics lessons. It explain each compiler functions as it has to be explained. Sure enough it miss the Config Fuses section though.
    Manual do it's job. Pull-up, pull-down, extra hardware, decoupling caps, power supply, hardware layout, breadboarding... it's electronic basics lessons... which haven't to be covered by the PBP manual.
    Extra Feature of the PIC
    This one is one of the most common issue, this haven't to be covered by the PBP(C) manual... it is already covered in all respective piece of hardware datasheet... but people seems to barely read them... kinda sad. I'ts no way engineering tricks...it's datasheet reading. Everybody MUST do it... but forums exist, so other would do for you when question comes in. We haven't forum when i was at school...
    Engineering tricks
    There's no such things that really exist. There's conventional design rules, much more conventional rules and then the common sense practice... which are covered in any decent electronic lesson. Sure enough, we all have our own tricks discovered by any smoke-tests, bench tests.. and maybe sometime by using any kind of Sim software.. that's hardware. There's probably some programming tricks... but this imply you waste, spent some time on doing it. Problem is... not a majority of people doing this.. it's a kind of fear or something like that. One thing i'm not shy to say, if it wouldn't be this forum, i wouldn't probably that interested and experimented like i am right now. Maybe because i'm not afraid of reading datasheet and experiment with.
    As i often said here and there... what will be the worst case? Compilation errors or it simply doesn't work... WHAT'S THE BIG DEAL? Learning opportunity... period. Where the fear of learning new stuff comes... i don't know for sure, everybody's different... maybe because i'm a lab rat and have no real social life
    I learned MicroController at school in 90's... and we learned Z80 I learned PIC myself from scratch and by reading/helping other in this forum. I have the same resource as anyone, the same datasheet, the same manual, the same internet connection... maybe just more time to waste... maybe... could be also called... Time and interest in solving others problem BUT learning new tricks from it and later apply it in my own designs.
    <hr>
    I may agree that the "tone" of some user may have changed... is this motivated or not.. i don't want to know, but being member of 11 different forums (french/english) i can tell you this... people are quite polite in here.
