Random number results
Results 1 to 4 of 4
    Nov 2004
    Saskatchewan Canada
    Exclamation Random number results
    After that week of trying to understand how random would work here are some results from my test:
    Random number output from chip 12F629:
    2 - 5- 11- 7- 15 - 14 - 13 - 10 -4 - 8- 0 - 1 - 2 - 5
    11 - 6 - 13 - 10 - 5 - 11 - 6 - 13 - 10 - 4 - 8 - 0 - 1 - 3
    7 - 15 - 15 - 15 - 14 - 13 - 11 - 7 - 15 - 15 - 15 - 15 - 15 - 15
    14 - 12 - 9 - 2 - 5 - 10 - 5 - 11 - 6 - 12 - 8 - 0 - 0 - 1 - 3 - 6
    There does seem to be some strange duplications of numbers in the above string that was generated.
    0 - 4
    1 - 3
    2 - 2
    3 - 2
    4 - 1
    5 - 4
    6 - 4
    7 - 3
    8 - 3
    9 - 1
    10 - 4
    11 - 5
    12 - 2
    13 - 4
    14 - 3
    15 - 10
    Generally there is an even distribution of numbers in the above list except for number 15 which was generated at least twice as many times as any other number.
    0 - 7 count is 23
    8 - 15 count is 29
    These numbers were generated using:
    start:
    <b>Random rannum
    If rannum = 66535 then start ' get an even distribution of odd and even numbers
    number = rannum & $000F</b>
    I think the same results would come with:
    <b>Random rannum
    if rannum=66535 then start ' get an even distrubution of odd and even numbers</b> because either way only the first four bits are going to be looked at anyway.
    I used one LED per port on four ports that represented bits 0 to 3 that were generated.
    Anyone have any idea what might be up with those long strings of 15? This did show me that I may need to include a routine to stop the same number from being generated twice in a row.
    Overall I am quite pleased with myself. My test programs all eventually worked as planned after I did more reading. I compiled them on the free online demo version and now I think I will download the pbc so I can work on the bigger final program.
    Thanks for the help to this point!
    Bart
    I did a spread analysis when I first came up with results like yours... however, after taking 65535 samples and analysing the results, I discovered that the spread is pretty equal over a much larger sample. There's no guarantee you'll get heads or tails an equal number of times flipping a quarter within a small sample quantity, but they'll pretty much ballance given a large enough sample. Remember your 'Probability' lessons back in Math at school.
    Nov 2004
    Saskatchewan Canada
    That class was many, MANY years ago!
    I did a bit more tweaking last night and added a routine to eliminate back to back duplicates. That smoothed things out quite a bit. I did get some interesting "patterns" however. The sequence 11 - 7 - 15 - 14 came up quite a bit, but the overall string itself was far more "random" - at least enough for what I need. I think I can safely move on to debugging the next part of the code.
    Bart
    seinfield's Avatar
    seinfield Guest
    You can implement a cellular automata, in the micro. There are some examples on the net in order to generate a pseudo random numbers using this method.
    I used a long time ago, in an AI course.
  1. Dynamic USB Serial Number (PIC18F4550)
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 16th July 2009, 18:03
  2. Random number seed
    By kwelna in forum mel PIC BASIC
    Last Post: - 1st February 2007, 18:33
  3. Working with the random number generator
    Last Post: - 16th January 2007, 18:50
  4. Searches
    By bearpawz in forum Forum Requests
    Last Post: - 7th November 2005, 19:47
  5. more random number questions
    By bartman in forum mel PIC BASIC
    Last Post: - 14th November 2004, 18:55
