Variable problem
Results 1 to 11 of 11
    hi
    Ok I try but I have a Problem!
    I have this :
    ML_Seconds Var Word [24]
    ML_Verz Var Word [24]
    Here is wrong too!
    Timer_Int:
    for M= 0 to 23
    ML_Seconds.lowbyte[M] = ML_Seconds.lowbyte[M] + 1
    Next M
    and now I must to compare this two Words
    for N = 0 to 23
    If ML_Seconds.lowbyte[N] => ML_Verz.lowbyte[N] Then ...
    Next N
    But I compare now just the lowest two Bytes,I need the word Data
    How I can do that ?!
    regards Pesti
    Not sure what the problem is, but are you sure you don't really want to have:
    ML_Seconds.lowbyte[M] =  ML_Seconds.lowbyte[ M + 1  ]
    And this:
    for N = 0 to 23
    Next N
    Easy enough:
    temp1 var byte
    temp2 var byte
    temp1 = ML_Seconds.lowbyte[N]
    temp2 = ML_Verz.lowbyte[N]
    if temp1 => temp2 Then.....
    Next N
    Hi Skimask
    thanks
    Ok but what is when the value for ML_Seconds.lowbyte[N] is grater then 255 I must to compare the highbyte too!?
    How is that are the two bytes in a word connected,i mean that when i increase the value in my ML_Seconds[N] and the value is going out of 255 then increase the highbyte automatically or not?
    regards Pesti
    Jeeze...then don't limit your inital compare to just the lowbyte...use the whole thing...
    Jeeeze....Can not Help me ;-)
    Mar 2006
    China
    Default I can try to help
    But I am seriously confused... I understand you have a problem comparing variables
    and I gather you want to compare 2 words from a word array
    for N = 0 to 23
    If ML_Seconds(N) => ML_Verz(N) Then ...
    Next N
    this should give you the N word from your array
    /me
    Ok
    Thanks Jumper,can I word arrays just increase like this:
    ML_Second var Word[24]
    ML_Alarm var bit [24]
    ML_End_Time var Word [24]
    for S = 0 to 23
    ML_Alarm[S] = 0
    ML_Second[S] = 0
    next S
    ML_End_Time[0] = 10 ' Seconds
    ML_End_Time[12] = 1000 ' Seconds
    ML_End_Time[23] = 10000 ' Seconds
    Tmr0_Int: 'Timer0 = 1 Seconds
    TMR0IF = 0
    for N = 0 to 23
    If ML_Alarm[N]= 1 then ML_Second[N] = ML_Second[N] + 1 'Start the Counter for that ML
    if ML_Second[N] = > ML_End_Time[N] then ML_Alarm[N]= 0: Gosub ......
    Next N
    Resume
    Regards Pesti
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. problem with variable on PIC10f202
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 17:29
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 07:59
