So your problem keeps changing?
http://www.picbasic.co.uk/forum/show...s+bytes+arrays
Thank you very much for the answer.
Now I understand!
You are the best!
regards Pesti
hi
Ok I try but I have a Problem!
I have this :
ML_Seconds Var Word [24]
ML_Verz Var Word [24]
Here is wrong too!
Timer_Int:
for M= 0 to 23
ML_Seconds.lowbyte[M] = ML_Seconds.lowbyte[M] + 1
Next M
and now I must to compare this two Words
for N = 0 to 23
If ML_Seconds.lowbyte[N] => ML_Verz.lowbyte[N] Then ...
Next N
But I compare now just the lowest two Bytes,I need the word Data
How I can do that ?!
regards Pesti
Not sure what the problem is, but are you sure you don't really want to have:ML_Seconds.lowbyte[M] = ML_Seconds.lowbyte[M] + 1
And this:Code:ML_Seconds.lowbyte[M] = ML_Seconds.lowbyte[ M + 1 ]
Easy enough:for N = 0 to 23
Next N
Code:temp1 var byte temp2 var byte .................... temp1 = ML_Seconds.lowbyte[N] temp2 = ML_Verz.lowbyte[N] if temp1 => temp2 Then..... Next N
Hi Skimask
thanks
Ok but what is when the value for ML_Seconds.lowbyte[N] is grater then 255 I must to compare the highbyte too!?
How is that are the two bytes in a word connected,i mean that when i increase the value in my ML_Seconds[N] and the value is going out of 255 then increase the highbyte automatically or not?
regards Pesti
Jeeze...then don't limit your inital compare to just the lowbyte...use the whole thing...
