MS-DOS Subsystem error
Results 1 to 5 of 5
    brooklyn
    didn't see your reply skimask.
    after the quote i made, the error is listed as some low level barf.
    check the link below for a good example. it would give different barf sometimes.
    i hope i'm on the right track now.
    http://www.picbasic.co.uk/forum/show...ubsystem+error
    When did it happened? After a Bootloader process, ICD, Serial communicator, Programmer launch?
    You could still manually shut down the NTVDM process in the TaskManager.
    I know i already had a problem like that, but it was long time ago... memory fade...
    EDIT: oh yeah i remember... it was when launching Picstart... in the ol' days, when i had PBP 2.40, MCSP could launch MPLAB 5.XX, then launch PicStart. The problem happened when closing MPLAB. It never prompted the error message, but i had to shut-down the NTVDM process, or i couldn't lauch Picstart again... that was years ago...
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
