18F2520 ADC issue
Results 1 to 11 of 11
    Default Halas ...
    Hi, Darrel and Jerson
    CVRCON would be a good Idea ... but it is cleared at each power-up, and there's no asm ... other than DT Instant interrupts !
    but the ADC still works ( it follows input, but as if a ghost divider was placed : for 3.4 v @ sensor input it "sees " 2.28v - confirmed by the voltmeter placed on the input pin )
    Now, after a power down, the problem comes back , first times after ~ half an hour, then quicker and quicker ... and finally at power up and continuously.
    if re-programming the device ... the problem still is here.
    Note the problem only occurs after ~ 30 Hours of work ... whether the chip stays in sleep mode ( 400 Hours ) or powered down.
    May be I should try another chip ... a 2580 i.e. ...
    Bombay, India
    Repeated failure after a fixed duration suggests stack problem to me. I can suggest you check the nesting levels in your code and if you have sufficient stack left over for interrupts use. Due to stack failure, the program could be returning to a wrong location and somehow modifying the CVRCON register and turning the AN2 port to output VREF. There may be other symptoms that accompany this.
    Hi, Jerson
    as the AN2 input permanently stays "damaged" after some times ... I do not think it could be a stack or soft problem ...
    as I wrote : re-programming the chip do not solve the issue ...
    let's say the program continue to run pretty fine, of course excepting what relies to AN2 input ...
    I must make some tests with RA2 as digital input/output ... just to try to see if something abnormal and verify if it is in the ADC input multiplexer or in the clamping diodes that the problem is ...
    Red face Found something ... BUT ...
    I finally found something ...
    I used AN0 to AN2 ... and AN3 for external reference.
    Innocently ... I had declared AN3 as analog in the ADCON1 register.
    Looking closer to the Datasheet ... The reference DO NOT use the ADC multiplexer path.
    So, I declared AN3 as digital ...
    AND The right AN2 value re-appeared !!!
    BUT that is because I do not use AN's inputs greater than 2 ... I would have to valid AN3 as Analog if using AN4 ...
    So problem is still here.
    I Just found a Turnaround ...
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 01:12
  3. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
