using MPLAB 8.0 ?
Results 1 to 4 of 4
    Default using MPLAB 8.0 ?
    Hi all ,
    I need your help how to begin programming using MPLAB , I use PBP good but I need to learn MPLAB so how I can begin , every time I make a programm in mplab I got errors , Is there a good tutorial how to begin using it.
    thanks for all
    What kind of errors are you getting? And have you started with the instructions here to have PBP work with MPLAB?
    http://www.melabs.com/support/mplab.htm
    Quote Originally Posted by iugmoh View Post
    Hi all ,
    thanks for all
    Read this thread...completely...and re-read it...
    http://www.picbasic.co.uk/forum/showthread.php?t=1742
    Begin with mackrackit's link. Bear in mind that if you set the config fuses in your code, you must use the MPASM syntax.
  1. PICBASIC Pro & MPLAB integration syllabus
    By chris vp in forum PBP Wish List
    Last Post: - 25th July 2009, 10:35
  2. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 01:15
  3. pbp --> mplab broken again
    By kenif in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 18:57
  4. Microcode Studio MPLAB support
    By jbpaul in forum General
    Last Post: - 27th November 2006, 06:55
  5. melabs USB programmer into MPLAB?
    By jocovo in forum General
    Last Post: - 10th November 2006, 16:58
