Pic Development Board
Results 1 to 40 of 42
    Default Simple 16x2 lcd code
    Tacke all j14 jumpers and use the jumper wires to conect the port and lcd
    Conections:
    J14 - PIC PORT
    PIN2 - PortB.2
    PIN3 - GND
    PIN4 - PortB.3
    PIN11 - PortB.4
    PIN12 - PortB.5
    Pin13 - PortB.6
    PIN14 - PortB.7
    @ Device HS_OSC ' High Speed Crystal
    define OSC 20
    Include "modedefs.bas" ' Include serial modes
    ' Define LCD registers and bits this time not use it for later apps..
    Define LCD_DREG PORTB 'Lcd D 4-bit parallel register starts at PortB.4 to PortB.7
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 2
    Define LCD_EREG PORTB
    Define LCD_EBIT 3
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    DefineLCD_LINES 2 'Number lines on LCD
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    LCDOut $FE, 1 ' Clear screen
    Pause 500 ' Wait .5 second
    LCDOut "Ola Paulo Filipe Santos" ' Display "Ola Paulo Filipe Santos"
    Have fun.
    Aug 2010
    Default Questions about these dev boards
    Sorry for bringing back this old topic, but there seems to be a lot of knowledgeable users of these products. I've been looking at both the EasyPIC6 and QL200, and I have to say I'm leaning to the EasyPIC, mainly for support and documentation reasons. But I've had a hard time trying to determining a couple of things about it.
    Firstly, is the MCU shown in the photos included, and what type is it? It doesn't seem to explicitly show this information on their site or in the documentation.
    From what I've read, I can use MPLAB (and Hi-Tech C or Microchip C18, etc.). I usually use Pickit2 or 3 to program my PICs, but I assume the board will come with drivers for the mikroICD interface for MPLAB? I'm wrong on these points?
    Also, will it only drive the MCU and peripherals at 5V, or can other voltages (eg. 3.3V) be used/selected?
    Thanks in advance,
    Angelo
    Aug 2008
    Portugal
    I've got an EasyPIC6 Board. The board comes with 1 PIC16F887. I think you have ane option on MikroEkektronic site, that you can purchase the board with 1 - 2X16 LDC and 1 GLCD with touchpanel. Mine, was purchased with this items.
    Thanks and Regards;
    Gadelhas
    malc-c's Avatar
    malc-c Guest
    I have an EasyPIC5 and it came with a 16F877 (or 877A - can't remember). I comes with it's own software for loading the compiled HEX which can be generated through MSC and MPASM (the latter being part of Microchips MPLAB]
    Personally I would recommend the any of the EasyPIC boards for most of the reasons you mentioned plus there are loads of additional boards that simply plug onto the headers, and example is shown below
    I've been happy with my EP5 board and feel it's been well worth the investment. Yes the downside is that it runs at 5v and there is no 3.3v regulation - but then maybe the EasyPIC7 is just around the corner ????
    Interestingly having revisited the LQ site they have a board that features support for a range of 16bit chips http://www.pic16.com/en/wzcapi/dsPIC3.htm
    It also has some nice features like serial over Ethernet on board
    Quote Originally Posted by ARQuattr View Post
    Yes, the board allows you to program with Mikroe's PicFlash programming utility using the USB port on the board. This is a pretty nice utility. I too use the Pickit2 and like that very much, but the PicFlash was not hard to get used to. It can also be adjusted to work with MicroCode Studio for one button compiling & programming.
    I think the bummer part of the board, is that it does not allow you to use it with both 5 and 3.3 volt devices. I started messing with the power supply to hack it a bit, but selected the wrong resistor, so I have a little more work to do to see if I can make my own selector switch. Of course, I doubt if I can get any of the LCD's to work with that hack.
    They now offer another board that only does 3.3 volt devices. http://www.mikroe.com/eng/products/v...opment-system/ I currently use a breadboard for 3.3v devices.
    http://www.scalerobotics.com
    Aug 2010
    Thanks everyone for your helpful replies.
  1. microcode studio and ql200 development board
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 1st October 2015, 17:28
  2. Pretty cool display and development board PIC_LCD3310
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 17th April 2010, 10:05
  3. pic first build test board not running
    By comwarrior in forum Schematics
    Last Post: - 29th June 2009, 16:48
  4. universal PIC Board (PCB)
    By NavMicroSystems in forum Schematics
    Last Post: - 19th September 2005, 19:13
  5. Development Board
    By carl_schell in forum Adverts
    Last Post: - 21st July 2004, 08:39
