Hi Malc,
I was impressed with the board. I received mine last week so here are the settings to use the onboard USB programmer with MCode.
Select the Compile and Program options (its under 'View' for some reason?)
Select the Programmer Tab then click on 'Add new Programmer'
Select 'Create a custom programmer entry' and click 'Next'
Enter any name you want to identify this programmer and click 'Next'
Enter the program filename PICFLASH.exe
Enter the file path (yours may be different) C:\program files\Mikroelektronika\PICFLASH-mikroICD
Enter the code parameters -pPIC$target-device$-f$hex-filename$
Click 'Finished'
Then 'OK'
Now its ready...........
Bob
