Math Help Please
Results 1 to 14 of 14
    Ohio
    RPM Max = 12,000
    STRAIN Max = 210
    TORQUE Max = 143
    I have version 2.44 of PicBasic Pro. Will 'LONG' work with this version? Should I upgrade?
    Mark
    Quote Originally Posted by markcadcam View Post
    RPM Max = 12,000
    STRAIN Max = 210
    TORQUE Max = 143
    Mark
    Upgrade yes... Check the website for more info...
    12000 x 5252 x 210 x 143 = 1,892,610,720,000
    Way too big for long's...
    Like BrianT said, you'll have to figure out how to do some mathematic gymnastics to keep your numbers low enough to fit in 31/32 bits...
    Or you could do it the old fashioned way, like back in 2nd grade...one number at a time, carry the result if needed...and so on and so on...
    I guess it's up to you to figure out how much accuracy you really need/want...
    Ohio
    Divide by 5252, not multiply it.
    RPM = 12000
    STRAIN = 210
    TORQUE = 140
    VALUE = 5252
    A = STRAIN * TORQUE
    B = RPM
    C= A * B
    C= C DIV32 VALUE
    I knew that
    Ok,
    12000 x 210 x 143 = 360,360,000 which will fit into 31/32 bits.
    but that result x 100 won't...so...
    x100 /5252 is the same as x25 /1313
    rpm x strain x torque / 1313 x 25 = result (with decimal point shifted over)
    assuming you've used LONG variables.
    Ohio
    Where is the x100 coming from?
    Another...'OH YEAH' moment just happened.
    You've already got the 'torque' value multiplied up for the decimal point.
    Disregard the stuff about x100/5252.
    12000 x 210 x 143 = 360,360,000 which will fit into 31/32 bits even when getting maximum values.
    Divide that by 5252 and you get 68613, which is 100x too much, right?
    So divide that by 100, gives you 686, take the remainder (modulus) and you get 13.
    Should be easy enough to display that (until you get to the leading zeros...PBP CAN handle that too if you read far enough into the LCDOUT and/or SEROUT section of the manual).
    Ohio
    I think I got it now. Thanks for the help.
    Mark
  1. Resolution integer math assistance?
    Last Post: - 14th January 2010, 04:01
  2. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  3. Pulsin Math question
    Last Post: - 2nd April 2008, 17:15
  4. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  5. not quite understanding the MATH function
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 17th January 2006, 21:20
