Step Motor Control
Results 1 to 3 of 3
    Blasfemy's Avatar
    Blasfemy Guest
    Default Step Motor Control
    Hey, i'm new here but i would like some help on a program for a step motor.
    I'm using a timer to operate at 300Hz and the same timer to operate as a delay of 1800.
    So, first i turn on the first bit during some time and then my interrupt routine just calls the 2 timer after the first is finished. But i think i have some error on my interrupt routine and function so i will just copy it and you could comment it:
    void init_timer1(){
    OPTION_REG=00000011; //0xDF;
    //t0cs = 0;
    //psa = 0;
    //ps2=0; ps1=0; ps0=1;
    TMR0=0x0F;//47 Este timer começará no valor apropriado de modo a fazer o overflow no tempo certo
    Flag=1;
    void init_timer2(){
    //t0cs = 0;
    //psa = 0;
    TMR0=0x0F;//221 Este timer começará no valor apropriado de modo a fazer o overflow no tempo certo
    Flag=0;
    void interrupt Timers(void)
    if (TOIF==1 && Flag==1)
    TOIF=0;
    Flag=0;
    init_timer2()
    if (TOIF==1 && Flag==0)
    TOIF=0;
    Flag=1;
    init_timer2()
    void Halfstep(){
    while(1){
    init_timer0();
    PortA = 0x08;//1 0 0 0////
    I would've thought that this URL:
    www.PICBASIC.co.uk
    should've been a big enough hint...
    Guess not...
    forum.microchip.com
    Mar 2012
    Default Re: Step Motor Control
    Hello, I know it's a bit late, but did you use any Input Capture for your control? If so, please let us know. If you remember eventually...
  1. Motor Stepper Example
    Last Post: - 3rd January 2015, 17:58
  2. Skipping link step. Not all sources built successfully
    By Jalves in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 19:25
  3. motor step
    By fox_53 in forum mel PIC BASIC Pro
    Last Post: - 13th May 2008, 03:05
  4. m looking for those who deal with step motor drivers
    By Augur in forum Forum Requests
    Last Post: - 6th July 2007, 05:52
  5. explanation of step array
    By Rabm in forum mel PIC BASIC Pro
    Last Post: - 29th September 2006, 18:00
