Final Button Code
Results 1 to 18 of 18
    May 2008
    Texas
    Thumbs up
    meersee buukuu alain (bad french accent)
    gonna grab some of that code you worked up...this is for residential so the temps I am working with will be from about 60 degrees F to 80 degrees F for setpoints and 20 degrees F to 120 degrees F for the outside reference temp.
    thanks again
    Bryan
    Hi, WP
    Not so bad for the accent !!!
    a small forgotten thing
    Aff:'Affichage temp
    'préparation chiffre : sign = 1 = valeur négative
    Loscale = ( TempC /5 + Sign ) * 5  + Sign << 7
    Decal = 0
    Decal	= ( TempC // 5 ) << 1
    IF Sign THEN
             Decal = 10 - Decal
    	IF Float > 25 AND Float <= 75 then Decal = Decal - 1
    	IF Float > 75 Then Decal = Decal - 2
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 07:16
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
