Help please with i/p o/p hold delay
Results 1 to 5 of 5
    Oct 2007
    Default Help please with i/p o/p hold delay
    Hi all,
    I am using a 12F675, running its internal clock.
    What I am trying to get my head around some timing loops,
    I am trying to do following...
    I need an output to trigger as soon as the pic gets an input, (easy)
    But it needs to hold latched for about 20 seconds from the time the input is released.
    If an input is applyed to the pic within the 20 seconds the timer needs to reset back to 20 seconds until the input is released. (then carry on as before)
    I then need to be able to cancel the 20 second delayed latch by applying a second input
    to the pic. (clearing the delay and lifting the latched output)
    Any ideas or advice would be great,
    Cheers
    Dave....
    What is the minimum duration of these input pulses that will be doing the latching and resetting?
    Oct 2007
    Default Help please with i/p o/p hold delay.... info
    The input pulses are actualy toggled inputs,
    The input can be anything from 1 second to several mins.
    The pic circuit is actualy going to be used in a low power radio link,
    and its to control the transmit delay to stop it from chattering.
    Cheers
    Dave..
    Quote Originally Posted by g7jiq View Post
    If the input is slow like that, then your program is practically written by the wording in your first post...
    Oct 2007
    Default Yes.. But where do I start..?
    I have grasped the basics,
    but when it comes to timing loops I am beat.
    I have only been into pic programming for just over a year,
    and are learning fast.
    Half the problem is knowing where to start,
    If you possibly could draft out a bit of program code,
    I would be greatful.
    Cheers
    Dave....
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Help writing pic program with i/p o/p hold delay
    By g7jiq in forum mel PIC BASIC Pro
    Last Post: - 27th May 2008, 22:58
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 20:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 01:10
