Strange problem with Serin/Serout on 16F628
Results 1 to 24 of 24
    I am assuming that what he is implying is that if your pin is a ST, you can not use it for serial communication. Is that correct?
    Nope. If you're using an ST type input this just means that your external device sending serial data to the PIC has to meet the minimum input threshold levels for the ST input.
    As for the portA pins, have you disabled A/D so you can use these pins as digfital inputs?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2006
    Florida, USA
    Bruce - Thanks for your reply. What you said is starting to make sense... For a ST pin to recognize input, it has to reach ~4V. For a TTL pin to recognize input, it has to only reach ~2V. Is that correct? So what you are saying is that in order to use a ST pin for serial input, the "signal" needs to be ~4+ Volts. And I am assuming that in most cases this would require a MAX232 to achieve those levels. Correct?
    OK, let's just forget about the input for the time being. Can I use a ST pin for TXmit without any problems? Right now, the program transmits (supposed to) the commands to start playing when it receives a trigger. Well, I don't seem to be able to do that either. Any thoughts?
    Here's my code:
         INCLUDE "modedefs.bas" 'Needed for serial communication
    @ DEVICE HS_OSC              ; Hi Speed Osc
        ADCON1 = 7          ' Set PortA Pins as I/O pins
        CMCON = 7
        Trigger     var PORTC.6
        PlayLED     var PORTD.1
        TXPin       var PORTA.2 'E.1
        RXPin       var PORTA.3 'E.2
        B0          var byte
        CR          CON 13       ' constant value of a carriage return
        low playled
        PAUSE 3000                               'allow VMusic2 to initialize
        SEROUT txpin, T9600,["VST",CR]           'stop anything that's playing
    Loop0:
        if trigger = 0 then goto loop0 'button is pulled low via 10K resistor
        high playled
        SEROUT txpin, T9600,["VPF file000.mp3",CR] 'Play a file named "file000.mp3"
        PAUSE 2000
        SERIN rxpin, T9600, [">"],B0 'Waits for ">" to indicate playing done
        low playled
        PAUSE 2000
        goto loop0
    Look in the Electrical Characteristics section of the PIC data sheet. Look under Input
    High Voltage. For a Schmitt Trigger type input you'll see something like 0.8 Vdd under
    the Min column with Vdd under the MAX column.
    What this means is; Minimum input that will be recognized as a logic 1 would be about
    0.8 times Vdd. The MAX input level of course should not exceed Vdd.
    Now look a bit farther to the right under Conditions. If this states "for entire Vdd range"
    then this means 0.8 times whatever voltage you're operating at, that is within the spec
    for Vdd, would be what you use for the input threshold calculation.
    I.E. if the PIC you're using can operate from say 4V to 5.5V, then you would use whatever
    Vdd is to figure this out.
    Let's assume you're using a 4V supply. 0.8 * 4V = 3.2V. This would be the minimum input
    level you need on the ST input to be recognized as a solid logic 1. This is the logic 1 input
    threshold level.
    Now look at the TTL input requirement. It may look something like this. Under the Min
    column it shows 2. Under the Max column it shows Vdd. To the right it may be something
    like 4.5V ≤ VDD ≤ 5.5V
    2V is the minimum input level that will be recognized as a logic 1. Vdd is of course the MAX.
    The 4.5V ≤ VDD ≤ 5.5V means (if Vdd is greater than or equal to 4.5V and less than or
    equal to 5.5V), then you're operating within spec.
    Output levels are also listed just below this section. A pin outputting a logic 1 will normally
    be Vdd-0.7V, which just means you can expect a drop of around 0.7V due to the output
    driver. If you're operating at 5V, then 5V-0.7V is what you can expect the output pin to
    deliver to the load.
    Yep. ST only refers to input pins. The DC Characteristics section of the data sheet will
    show what you can expect for a drop in the output driver. Normally it's around Vdd-0.7,
    but it never hurts to check.
    -Bruce
    tech at rentron.com
    Sep 2006
    Florida, USA
    Bruce - Thanks for your elegant explanation - I now perfectly understand the difference between ST and TTL level inputs. Nicely stated!
    And what you said about ST pins being used as xmit pins indicates that I should probably not have a problem doing that (I'm running at 5V, btw). Did you see any problem with my code as to why I don't seem to be transmitting to the player? Since I am not using a 232 chip, I am using the T9600 command (as opposed to the N9600 command). The Xmit and RCV pins (A.2 and A.3) are wired directly to the Xmit and RCV pins of the player. Should I be doing anything special with these connections? Like I said earlier, this works fine on my 628 board.
    I appreciate your help. I am at wits end - it just doesn't make sense... Thanks!
    How do you know that you're not transmitting data to the player?
    Have you looked at the tx output with a scope? Have you tried inverted mode?
    Could be your player requires inverted serial. That would explain why it isn't responding.
    Edit: You show @ DEVICE HS_OSC but you don't show any DEFINE OSC. If you're using
    anything other than 4MHz, you'll want to define that oscillator speed. PBP assumes 4MHz
    unless you specify otherwise, and that will for sure screw-the-pooch with timing if you're
    not using a 4MHz osc. If you are using a 4MHz osc, you may want to switch to @ DEVICE
    XT_OSC so you're not over-driving your 4MHz osc.
    -Bruce
    tech at rentron.com
    Sep 2006
    Florida, USA
    Bruce - When it gets the valid command to play the sound clip, it plays. There is a status LED on the player that flashes when it gets the comand. It does not do that. I can take this player off the 877 board and can put it on the 628 board running the same code and it works fine. The only difference is that I am using A.3 and A.4 on the 877 for communication and B.6 and B.7 on the 628 board. Everything else is the same. That is what is so frustrating - it's like rotating your tires and now your car won't start. Rotate them back and everything works fine! Makes no sense!
    Thanks again for all your help!
    Interesting problem. You seem to have everything configured OK for A/D & comparators off
    with ADCON1 = 7 & CMCON = 7. Have you verified the PIC is even running by blinking an LED?
    Edit: hold the phone. Your code indicates you're using A2 for TX and A3 for RX.
    If you're using A4 for TX, this pin is an open drain output. I.E. it can't go high!
    -Bruce
    tech at rentron.com
    Maybe, just maybe.
    http://www.picbasic.co.uk/forum/showthread.php?t=562
    I might be wrong But I do not think A.4 will work for tx.
    edit
    Better late than never, did not see the above post
  1. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 09:33
  2. PIC stop responding - Strange Problem!
    Last Post: - 31st August 2009, 14:06
  3. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:47
  4. Another Serin/Serout Problem!
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 16:26
  5. 16F628 on-chip eeprom problem
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 07:43
