Its possible to conect 18f4550 to usb device?
Results 1 to 22 of 22
    Today i get the VDIP2, im reading a lot about this part and how to use it with a pic http://www.picbasic.co.uk/forum/show...highlight=vdip like to thank especially to BrianT for is great job my code is based on is.
    Here is the data from VDIP2 http://www.vinculum.com/documents/da...s/DS_VDIP2.pdf
    Im very new at all this and i have a lot of concerns on doing this (the part is not very cheap 32€ im afraid to kill her) as i read from BrianT e have to reflash it and i do not now if i need to do the same a not clear how to and what firmware to put.
    Ftdi do not suport very well me...
    I to do not now if i need to put some resistors in the pic vdip2 connections?
    My 1st idea was and is to connect a pic to a nokia 6230 with is original usb data cable and sending sms and macking calls..
    Here my traing code
    DEFINE LOADER_USED 1
    define OSC 20
    Include "modedefs.bas" ' Include serial mode
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    'bits 2 & 3 temporarily inputs
    TrisC.2=0 'active LOW reset line to VDIP2
    TrisC.3=1 'Cts# Flow control to VDIP2
    TrisC.4=1 'Rts# Flow controlto from VDIP2
    TrisC.5=0 'Led to see if pic and code is ok blink 3 times
    TrisC.6=0 'Rx VDIP2
    TrisC.7=1 'Tx VDIP2
    B0 var byte
    High portb.5
    Pause 500
    Low portb.5
    Pause 500
    High portb.5
    Pause 500
    Low portb.5
    Pause 500
    Start:
    High PortC.2 'active LOW so not reset
    Low PortC.3 'pull VDIP2 pin CTS low
    Input PortC.2 'from VDIP2 pin RTS
    High PortC.6 'condition serout pin to mark state
    Pause 5
    HSEROUT ["AT", 13]
    HSEROUT ["ATD=+351xxxxx000;", 13]
    STOP
    Please comment anf if some one can hellp me...
    Thanks for all and sory for this long letters and less good work post.
    By by
    I've got a small question...
    What good is a 10us delay between 2 9600 baud HSEROUT statements, when, at 9600 baud, a bit takes 104.1us?
    Just like i said i just try to adapt the BrianT code for my needs and i do not have many experience with coding pics sow i will erasit now.
    My bigests concerns at moment are if i need to reflash de VDIP2 and how and with what firm. if there is a need of puting some resistor... in pic-vdip2 connections and then the code..
    Thanks for caring and i be grateful if you can hellp.
    Bt by
  1. USB Bootloader.
    By HenrikOlsson in forum USB
    Last Post: - 2nd May 2013, 02:46
  2. USB Device Not Recognized ???
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 00:53
  3. 18f4550 Device not recognized
    By garethconner in forum USB
    Last Post: - 22nd December 2007, 03:00
  4. How can I turn off USB support in 18F4550
    Last Post: - 6th September 2007, 03:56
  5. usb - device not recognised
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 8th January 2007, 17:47
