Tach Project (binary counting)...
Results 1 to 9 of 9
Threaded View
  1. #3
    Originally posted by mister_e
    The same weird situation will happen also when using SPI EEPROM.
    As i can see, the device don't accept the non decode mode. So $0F is Blank output. The only thing i can suggest is add
    HIGH Load
    Pause 20 ;maybe unecessary
    before Gosub DecodeMode line.
    let me know
    regards
    Hi mister_e,
    I tried your suggestion with the Pause 20, it had no effect. As far as $0F value I re-wrote the the shiftout command so that it now passes the binary equivalent. This works great for certain binary numbers. As an example:
    00001111 (works)
    00011111 (doesn't work)
    00001111 0000111 00001111 00000111 (works)
    00001111 0001111 00001111 00011111 (doesn't work)
    I can adjust any bank with certain binary numbers. I've posted modified code below. Along with some photos of the setup. One curious affect is that no matter what binary numbers I have "ON" after a period of time ALL the banks will turn off.
    Thanks for the suggestions I really appreciate it!
    Netjammer-
    Here is the code...
    ' File......MAX7219
    ' Purpose...
    ' Author...
    ' E-mail....
    ' Started...
    ' Updated...
    ' {$PicBasicPro 2.5}
    include "modedefs.bas"
    ' -----[ Program Description ]---------------------------------------------
    ' 4 Sets of 8 LED's (32 total). Each Dig# able to have an 8 bit number
    ' assigned to it.
    ' -----[ Revision History ]------------------------------------------------
    ' -----[ I/O Definitions ]-------------------------------------------------
    symbol DOUT = PORTC.5 'line for data input connected to RC5
    symbol CLK = PORTC.3 'CLK line connected to pin RC3
    symbol Load = PORTA.3
    ' -----[ Constants ]-------------------------------------------------------
    IsLow CON 0
    IsHigh CON 1
    ' -----[ Variables ]-------------------------------------------------------
    COUNter var byte
    ' -----[ EEPROM Data ]-----------------------------------------------------
    ' -----[ Initialization ]--------------------------------------------------
    ' -----[ Program Code ]----------------------------------------------------
    Begin:
    GOSUB DecodeMode
    GOSUB ShutDownMode
    GOSUB ScanLimit
    GOSUB Intensity
    ' gosub displaytest
    Continue:
    'first LED bank
    LOW Load
    ShiftOut DOUt,clk,MSBFIRST,[%0000000100001111\16]
    HIGH Load
    PAUSE 100
    'second LED bank
    LOW Load
    ShiftOut DOUt,clk,MSBFIRST,[%0000001000111000\16]
    HIGH Load
    PAUSE 10
    'third LED bank
    LOW Load
    ShiftOut DOUt,clk,MSBFIRST,[%0000001100000111\16]
    HIGH Load
    PAUSE 10
    'fourth LED bank
    LOW Load
    ' 87 0
    ShiftOut DOUt,clk,MSBFIRST,[%0000010011100000\16]
    HIGH Load
    PAUSE 10
    GOTO continue
    ' NEXT
    ' -----[ Subroutines ]-----------------------------------------------------
    DecodeMode:
    LOW Load
    ' SHIFTOUT DOUT, CLK, MSBFIRST,[$090F\16]
    SHIFTOUT DOUT, CLK, MSBFIRST,[$0900\16]
    HIGH Load
    PAUSE 20
    'Set shutdown mode so device is active
    ShutDownMode:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[$0C01\16]
    HIGH Load
    PAUSE 20
    'Set scan limit mode for three digits
    ScanLimit:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[$0B03\16]
    HIGH Load
    PAUSE 20
    'Set intensity of LEdDs
    Intensity:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[$0A09\16]
    HIGH Load
    PAUSE 20
    'Set Display Test mode active
    DisplayTest:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[$0F01\16]
    HIGH Load
    PAUSE 20
    Photo attached...
    Last Post: - 8th March 2010, 21:58
  2. PIC16F628 - Convert Binary to BCD?
    By steng in forum mel PIC BASIC Pro
    Last Post: - 20th March 2009, 09:17
  3. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  4. help required regarding reading binary files
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 4th March 2008, 23:30
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
