Display problems
Results 1 to 7 of 7
Threaded View
    New Hampshire
    Unhappy Display problems
    Howdeedoo all...
    I'm stuck here. I'm trying to get an Optrex DMC20481 (4 x 20 display) to work with a 16f877 and I'm getting nuttin! It doesn't even flicker. I've checked and re-check the wiring. It all looks good. I disconnected the LCD and wrote a simple program to pulse the connector pins... the data seems to be getting through fine telling me it's not likely a circuit board problem.
    This is a new circuit board with a 3-8 decoder enabling one of several paths for portd through 74HC373 chips. The decoder inputs are connected to porte of the 877.
    I am using Microcode Studio with the latest version of PicBasic Pro.
    I've probably dones something screwie. Any input here would be most appreciated.
    Thank you,
    Ross
    DEFINE LOADER_USED 1
    DEFINE osc 20
    ADCON1 = 7 'set porta to digital
    TRISA = 0 'set porta to output
    TRISD = 0 'set portd to output
    TRISE = 0 'set porte to output
    Define LCD_DREG PORTD 'I/O port where LCD is connected
    DEFINE LCD_DBIT 4
    DEFine LCD_RSREG PORTD 'Port where RS pin located
    define LCD_RSBIT 2 'Register select pin
    Define LCD_EREG PORTD 'Port where Enable pin located
    DEFINE LCD_EBIT 3 'Enable pin
    DEFINE LCD_BITS 4 '4-Bit data bus
    define LCD_LINES 4 'Number of LCD Character Display lines
    'Porte is connected to 74HC138 3-to-8 line decoder which directs portd to one
    'of several devices by enabling the correct 74hc373.
    porte = 5 'Enable 74hc373 connecting Portd output to LCD
    pause 2000 'Two seconds for display power-up (should be enough)
    lcdout $fe,1 'Clear the LCD screen
    pause 100 'Don't think I need this pause
    porta.0 = 1 'initialize porta.0 (where LED is connected)
    gosub flash_led
    lcdout "Success"
    lcdout $fe,1
    'Led is connected to porta.0. As the main program loops, it flashes the LED as
    'visual feedback that the program is at least trying to work. *razzberry*
    flash_led:
    pulsout porta.0,50
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  4. 64 led display problems
    By battousai923 in forum mel PIC BASIC
    Last Post: - 29th November 2007, 10:19
  5. Replies: 14
    Last Post: - 26th September 2007, 06:41
