Do READ and WRITE for PIC16F690 onboard EEPROM need 10ms pause?
Results 1 to 5 of 5
    READ or I2CREAD does not need a pause - ever. Whether it is external or internal EEPROM it does not matter.
    WRITE (for internal EEPROM) does not need a pause as it is handled already by PBP.
    I2CWRITE however DOES need a pause because PBP does not know if you are writing to an EEPROM or some other I2C device. Check with your external I2C devices Datasheet to see what your pause (if any) should be.
    xnihilo's Avatar
    xnihilo Guest
    Thank you very much, now I know.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
