Hex Value
Results 1 to 3 of 3
Thread: Hex Value
    Jun 2007
    Default Hex Value
    Hi All
    It has been a while since I have worked with Proton and I am still learning
    I have got a problem whre I want to send a Hex value
    Say I have got a value of 85 , I then want to send Hex 85("$85") not 55 witch is the Hex of 85
    I have tried some codes , but no luck
    Dim Val1 as Byte
    Dim Val2 as Byte
    Val1 = 85
    delayms 100
    serout port,baud,[Val1]
    'Got out 55
    serout port,baud,[# Val1]
    'Got out 38 35 must just be the 85
    Val2 = $Val1
    serout port,baud,[Val2]
    'Got out 00 but if you put in Val2 = $85 I get out 85 is Val2 = $Val1 not the same as
    Val2 = $85 ?
    Any help
    Wish I could help you but...here we do Pic Basic. Might try another forum.
    Perhaps the HEX modifier instead of # would solve your problem?
    Val1=$85
    SEROUT ...[HEX2 Val1]
    Pds forum....
    www.picbasic.org/forum
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. Configuration bits in a HEX file gone missing?
    By grzes.r in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2010, 02:10
  3. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  4. Reading from External Hex Address...
    By sbouda in forum mel PIC BASIC Pro
    Last Post: - 30th October 2008, 07:33
  5. INH8XM HEX file structure
    Last Post: - 30th December 2006, 23:46
