PortA 16F627
Results 1 to 4 of 4
Thread: PortA 16F627
    Jan 2008
    Dublin, Ireland
    Default PortA 16F627
    Hi
    I have a few questions relating to the use of portA on this PIC.
    The pin outs describe pin 4 as RA5\MCLR, if not used as MCLR does this mean I can use RA5 as a regular output and if so, how?
    Also the same is true for pin 15 = RA6\OSC2\CLKOUT. I am using the internal OSC so how do I use this pin as a regular output?
    Any help is appreciated
    Tony
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by tonyfelloni View Post
    Change the CONFIG fuse bits... except for the fact that RA5/MCLR can only be used as an input.
    Same thing, change the CONFIG bits to change the oscillator mode (Internal osc, RA6 I/O)
    Jan 2008
    Dublin, Ireland
    Thanks Guys
  1. error worring pbp247
    Last Post: - 17th January 2010, 04:51
  2. PortA digita input?
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 21:55
  3. 16f876 PortA set-up trouble?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 19:31
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
  5. 16F627 porta problems
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 7th September 2003, 10:40
