Could I have some advice on Which Pic Please?
Results 1 to 15 of 15
    Wink
    Hi, Karen
    with the external Xtal or reso ... 16F628/648 will be unbeatable !!!
    with internal 8Mhz clock ... 16F88 or 16F819 ...
    18F1320 ... I had small problems with mine ( no more than 20 reprogrammings available , EEPROM single location programming ... FALSE !!! Works well ONLY with more than two writings ... )
    searchtool here also:
    http://melabs.picbasic.com/Scripts/perl/picsearch.pl
    Had problems with my 18F1320's also using a Warp13a awhile back. Had to add an extra .1uf cap across Vdd/Vss, worked like a champ. Have been using PICKIT2 to do them the same way. Haven't tried it without the extra .1uf cap's though. Will do over this weekend and let you know.
    Cool
    Hi, Ski
    I've tried Picstart, ICD2, PicFlash and a programmer from one of our Magazines ( a serious one ! Lol ! ) ...
    Always the same answer ... only erasing seems to work.
    a second chip had refused Picstart programming for a moment ... and with the 8.0 MPLAB release, It miraculously came back to life ...
    I didn't insist further and "locked" it firmly on a PCB !!!
    Capacitor and/or 1K have been tried with no appearing result ...
    Now, I just program them from blank and send the PCB assembled ...
    µChip has been unable to tell me something about that ... and the error sheet didn't show anything suspect ...
    The memory issue needed to use the Brownout ... very,very bad idea aboard something flying !!!
    karenhornby, I would suggest using an 18F2620 as there are enough pins to do what you want as well as 2 CCP modules a voltage reference, comparator and you can run it at 40Mhz. if necessary. I have used these parts for many products over the last year and 1/2 and have had great success. If you are planning on laying out a pc board it will give you some extra pins to use in the future... It also has 4 timers and enhanced capture/compare for use with an H bridge later on if needed...
    Mar 2008
    Thanks guys
    All pretty helpful, and I never knew abt the reference page to look them up.
    The program I've written is 8k (the hex file is) and the reason I havent even considered the 18 series is i was as few pins as possible and dont need any complicated maths functions or add ons. It's going to be a simple switching circuit depending on what inputs are high will then determine what outputs go high and whats displayed oin the LCD display, it's that simple
    I actually never considered an internal reference it would cut component count down using internal too thanks
    The only problem stopping me using the 16F628A as suggested is the program size, i could add eeprom i guess but it's simpler to use a different pic than use more components.
    My idea is to make the project as small and compact as possible but still using discreet components and NOT smd's.
    Looks like it may have to be the 16F877A
    Thanks Everyone
    and Hi Dave, de Karen M3ZZZ
    Quote Originally Posted by karenhornby View Post
    You know what else might be even easier would be to post the code and see if any of us could possibly help you optimize it a bit more and make it take up less code space
    Mar 2008
    Sorry didn't do it b4 as I didn't want to ask for too much help.
    JUST changed the code to get rid up unneeded pins, i.e led o/p's that wont be on the final version it will only use the lcd
    What I'd like to do more neatly is have it so if PORTD.1 is pressed twice within the space of 2 seconds the program jumps to STOP1
    If PORTD.1 is ONLY pressed once then it jumps to PURGING:
    I'm sure there is a simpler way to do it than I've used.
    Oh Acetronics thanks I've actually deleted quite a few lines of code and actually have no idea what size it assembles to at the moment as the computer I'm using at the moment doesn't have a complier on it
    BUT when I compiled the code that you saw, the hex file was 8K (7.28K to be exact)
    Maybe I did things wrong, I dont know i'm still extremely new to this, I was using the Mikroe easypic5 when i designed the circuit, now I've got rid of that and am going to make up a circuit board with just the parts needed and program it direct using the ICD2 (hopefully )
    '*  Name    : Oil Control.BAS                                      *
    '*  Notice  : Copyright (c) 2008 [KarenH] *
    '*  Date    : 06/05/2008                                        *
                  Define	LOADER_USED	1
    @   DEVICE pic16F877a,HS_OSC,WDT_OFF,LVP_OFF
    ' Define various stuff
      DEFINE OSC 8
      DEFINE LCD_DREG PORTB       ' Set LCD Data port
            DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus .7
            DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
            DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
            DEFINE LCD_EREG PORTB       ' Set LCD Enable port
            DEFINE LCD_EBIT 5           ' Set LCD Enable bit i.e, PORTE.4
            DEFINE LCD_BITS 4           ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
            DEFINE LCD_LINES 2         ' Set number of lines on LCD to 4 Lines
            DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
            DEFINE LCD_DATAUS 50        ' Set data delay time in us
    ' Allocate variables
    command var     byte            ' Storage for command
    i       var     byte            ' Storage for loop counter
    temp    var     word            ' Storage for temperature
    DQ      var     PORTA.5         ' Alias DS1820 data pin
    DQ_DIR  var     TRISA.5         ' Alias DS1820 data direction pin
            ADCON1 = 7              ' Set PORTA and PORTE to digital
            Pause 500               ' Wait for LCD to start
            Lcdout $FE,1,"  All Circuits", $FE,$C0, " Funtioning  OK "      ' Display sign-on message
            Pause 3000              'Wait 3 seconds going any further
    ' Mainloop to read the temperature and display on LCD
      mainloop:
            Gosub init1820          ' Init the DS1820
            command = $cc           ' Issue Skip ROM command
            Gosub write1820
            command = $44           ' Start temperature conversion
            Gosub write1820
            Pause 500              ' Wait 0.5 seconds for conversion to complete
            Gosub init1820          ' Do another init
            Gosub write1820
            command = $be           ' Read the temperature
            Gosub write1820
            Gosub read1820
            ' Display the decimal temperature
           IF PORTC.0 = 0 AND PORTC.3 = 0 then lcdout $FE,1,"     Diesel", $FE,$C0,"Outside ", $fe, $C9, dec (temp >> 1), ".", dec (temp.0 * 5), $DF, "C":  LOW PORTE.0: LOW PORTE.1
           IF PORTC.0 = 1 AND PORTC.3 = 0 then gosub Tempcheck
           IF PORTC.0 = 0 AND PORTC.3 = 1 then gosub Tempcheck
           If PORTC.0 = 1 AND PORTC.3 = 1 then gosub Oil
           IF PORTD.1 = 1 Then GOSUB purging
    Goto mainloop           ' Do it forever
      Stop1:
    LOW PORTE.0
    LOW PORTE.1
    LCDOUT $FE,1,"     MANUAL",$FE,$C0," Diesel OVERRIDE"
    while PORTD.1=0           'OVERRIDE COMMAND to MANUALLY switch back to DIESEL i.e. if veg oil runs out
    wend
    pause 1000                 'so a very quick button press is NOT recognised and the program stays paused
    Goto Tempcheck
      OIL:
    LCDOUT $FE,1,"     Veg-Oil", $FE,$C0,"Outside", $fe, $C9, dec (temp >> 1), ".", dec (temp.0 * 5), $DF, "C"
    HIGH PORTE.0          'Diesel Solenoid
    HIGH PORTE.1          'OIL Solenoid
      Tempcheck:
    lcdout $FE,1,"    TEMP LOW", $FE,$C0,"Still on  DIESEL"
      Purging:
    LCDOUT $FE,1," PURGING Please",$FE,$C0,"      WAIT"
    LOW PORTE.1      'Oil Solenoid
    Pause 60000          'set delay of purge here 60 seconds
             gosub Stop1
    Goto mainloop
    ' Initialize DS1820 and check for presence
    init1820:
            Low DQ                  ' Set the data pin low to init
            Pauseus 500             ' Wait > 500us
            DQ_DIR = 1              ' Release data pin (set to input for high)
            Pauseus 100             ' Wait > 100us
            If DQ = 1 Then
                    Lcdout $fe, 1, "DS1820 not present"
                    Pause 500
                    Goto mainloop   ' Try again
            Endif
            Pauseus 400             ' Wait for end of presence pulse
    ' Write "command" byte to the DS1820
    write1820:
            For i = 1 to 8          ' 8 bits to a byte
                    If command.0 = 0 Then
                            Gosub write0    ' Write a 0 bit
                    Else
                            Gosub write1    ' Write a 1 bit
                    Endif
                    command = command >> 1  ' Shift to next bit
            Next i
    ' Write a 0 bit to the DS1820
    write0:
            Low DQ
            Pauseus 60              ' Low for > 60us for 0
    ' Write a 1 bit to the DS1820
    write1:
            Low DQ                  ' Low for < 15us for 1
    @       nop                     ' Delay 1us at 4MHz
            Pauseus 60              ' Use up rest of time slot
    ' Read temperature from the DS1820
    read1820:
            For i = 1 to 16         ' 16 bits to a word
                    temp = temp >> 1        ' Shift down bits
                    Gosub readbit   ' Get the bit to the top of temp
            Next i
    ' Read a bit from the DS1820
    readbit:
            temp.15 = 1             ' Preset read bit to 1
            Low DQ                  ' Start the time slot
            If DQ = 0 Then
                    temp.15 = 0     ' Set bit to 0
            Endif
            Pauseus 60              ' Wait out rest of time slot
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. newbe looking for PIC advice
    By Mad Professor in forum General
    Last Post: - 27th May 2009, 07:56
  3. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 00:26
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
