Problem with 16F877A but not with 16F876A
Results 1 to 11 of 11
Threaded View
  1. #4
    Wink
    Quote Originally Posted by savnik View Post
    I use BF199 and not 2N3904(as show at picture).
    The same circuit work on 16f876a.
    I believe the problem is with the configurations
    BF 199 has a "special" pinout ( b-e-c )... not the same as 2N3904 ... if my souvenirs are good ...
    and hfe is far lower than the 3904 ... ( I've just measured ~ 50 @ 2.5 ma on some of mines )
    the Only differences between 876 and 877 is the Port number ... as you do not use PORTD and PORTE ( I hope ...) , you can directly program the 877 with the 876 Hex !!!
  1. Problem displaying data from GPS module & using 16f877a
    Last Post: - 15th April 2010, 11:27
  2. 16F876A Bootloader Problem
    By Ashleyr01 in forum mel PIC BASIC Pro
    Last Post: - 15th April 2009, 19:21
  3. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
  4. 16F877A serin problem with baud rate 19200
    By leemin in forum Serial
    Last Post: - 31st July 2005, 10:45
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
