Buttons
Results 1 to 7 of 7
Thread: Buttons
    May 2008
    Texas
    Question Buttons
    I know this seems like a simple question, but I want to make sure my code is in the right ball park. The section of code should add 1 or minus 1 to a setpoint that another part of code will interpret and output to and lcd and turn on a red led or a green led
    ADCON1 = 7 ' Set PORTD and PORTE to digital
    Setpoint Var word
    Temp_Down Var PortB.3 'Temp down button input port
    Temp_Up VAR PortB.2 'Temp up button input port
    R_LED VAR PortB.0 ' Red LED output
    G_LED VAR PortB.1 ' Green LED output
    DQ VAR PortC.0 ' One-wire Data-Pin "DQ" on PortC.0
    Busy VAR BIT ' Busy Status-Bit
    Sign VAR BYTE ' +/- sign for temp display
    Dummy VAR BYTE ' Dummy for Div32
    R_Temp VAR WORD ' RAW Temperature readings
    TempC VAR WORD ' Temp in deg C
    TempF VAR WORD ' Temp in deg F
    Float VAR WORD ' Holds remainder for + temp C display
    Cold_Bit VAR R_Temp.Bit11' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    Real_Cold CON 1 ' Define Real_Cold = 1
    DS18B20_9bit CON %00011111 ' 93.75ms, 0.5°C
    DS18B20_10bit CON %00111111 ' 187.5ms, 0.25°C <-- My favorite
    DS18B20_11bit CON %01011111 ' 375ms, 0.125°C
    DS18B20_12bit CON %01111111 ' 750ms, 0.0625°C (default)
    OPTION_REG = $7f
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_10bit] 'Skip ROM search and write 10bit resolution to scratch pad
    Pause 500
    LCDOut $FE 'Clear LCD
    Setpoint = 22
    Start_Convert:
    OWOUT DQ, 1, [$CC, $44] ' Skip ROM search & do temp conversion
    PortB = 0
    If Temp_Up = 0 Then
    Setpoint = Setpoint + 1
    Endif
    If Temp_Down = 0 Then
    Setpoint = Setpoint - 1
    Endif
    lcdout $fe, 1, "Setpoint = ", #Setpoint
    If TempC < Setpoint Then
    high R_LED ' Turn on Red LED and turn off Green LED
    low G_LED
    Else
    High G_LED ' Turn on Green LED and turn off Red LED
    low R_LED
    EndIf
    Cool
    You can run, but you can't hide.
    Equally, you can create a new thread, but I can still reply.<hr>
    OK, resolution looks good.
    Start temp conversions OK,
    And the setpoint via buttons probably work too. (But a bit bouncy)
    Only thing left is to actually read the temperature from the DS18B20.
    ruthlessly,
    May 2008
    Texas
    Default aha
    One step ahead of you good sir
    I was able to read temp and actually write in a setpoint that turned on a green LED when temp was over setpoint and a red one when below.
    so maybe two steps
    You think I should use the button command to send the program to a subroutine that loops as long as the button is pushed? This way if you want to increase the temp by say ten you can just hold it down.
    Later
    Bryan
    Quote Originally Posted by WarPony View Post
    Hi, Bryan
    looks pretty good that way ...
    and also works pretty good with the BUTTON command which is really ideal for such use ...
    May 2008
    Texas
    Thanks Alain
    I am just starting to wrap my head around this stuff
    Lightbulb
    I knew there was an example in my projects ...
    mainloop:
    Writeok = 0
    delay = 0
    button Up, 		0, 255, 0, delay, 1, upbutton
    button Down, 	0, 255, 0, delay, 1, dwnbutton
    button Prog, 	0, 255, 0, delay, 1, Program
    Gosub Outsig
    PAUSE 18
    compte = 0
    Goto Mainloop
    upbutton:
    IF Down = 0 THEN
    	Pos = posn
    	Goto Jump1
    Endif
    	Compte = compte + 1
    	Select Case Compte
    		Case 255
    			Compte = Compte-1
    			N = 10
    		Case is > 50
    			N = 10
    		Case is > 15
    		 	N = 3
    		Case else
    			N = 1
    	End Select
       	pos = pos + 2*N
       	if pos > 2250 then  pos = 2250
    Jump1:
    For delay = 1 to 9
    	Gosub Outsig
    	Pause 18
    Next delay
    	Gosub Outsig
    Goto mainloop
    dwnbutton:
    IF Up = 0 THEN
    	Pos = posn
    	Goto Jump2
    Endif
    	Compte = compte + 1
    	Select Case Compte
    		Case 255
    			Compte = Compte - 1
    			N = 10
    		Case is > 50
    			N = 10
    		Case is > 10
    		 	N = 3
    		Case else
    			N = 1
    	End Select
       	pos = pos - 2*N
       	if pos < 750 then pos = 750
    Jump2:
    For delay = 1 to 9
    	Gosub Outsig
    	Pause 18
    Next delay
    	Gosub Outsig
     Goto mainloop
    Program:
    Compte = 0
    Test:
    IF Prog = 0 Then
    	compte = compte + 1
    	Gosub Outsig
    	Pause 18
    	IF Compte > 250 THEN Compte = 250: Goto Test
    	IF Compte >= 80 THEN WriteoK = Compte .4 : Goto Test
    	IF Compte >= 20 THEN WriteoK = Compte .2
    	Goto Test		'Attendre relāchement bouton ...
    Endif
    	IF Compte > 250 OR Compte < 20 Then mainloop
    	IF Compte >= 80 Then
    		pos = 1500
    		Goto Save	'remise au Neutre
    	Endif
    NB : WriteOk is the led that shows where you are ...
    Outsig is generating a servo pulse ...
  1. In Circut Debug (ICD) buttons palet is disable for 18F2620
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 17th June 2010, 05:21
  2. Button command question
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 08:44
  3. 6 Buttons
    By Johansch in forum General
    Last Post: - 4th July 2007, 15:21
  4. Buttons are driving me nuts
    By Doormatt in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 23:09
  5. Latched buttons
    By peu in forum mel PIC BASIC Pro
    Last Post: - 25th January 2006, 00:22
