Multiplexer channel selection
Results 1 to 18 of 18
    Quote Originally Posted by Castor View Post
    Please stay on topic.
    Guess what? Free help! Deal with it.
    'dcd channel selection
    low g_dcd
    for i=0 to 15
    	portb = (portb & %00011111 ) | ( ( i rev  3 ) << 5 )
    	portc = (portc & %10111111 ) | ( i << 3 )
    next i
    OR don't ADD
    low g_dcd
    for i=0 to 15
    next i
    OR don't ADD
    to get rid of the i lower bits for portC ...
    i would have used
    portc = (portc & %10111111 ) | ( i.3 << 6 )
    but, it's me ...
    portc = (portc & %10111111 ) | ( i.3 << 6 )[/code]
    I've tried to do something like that before. If I remember right, the fact that i.3 is a bit didn't work well with the << 6. It ended up shifting itself out into nowhere and always ended up being a '0'.
    Maybe that was back in the day, in an older version of PBP or something. It just seems to me like that didn't work very well.
    Wink
    I did at test on the breadboard this morning ...
    Everything fine ...
    Apr 2008
    Berlin, Germany
    This is the winner:
    I've tried both in MPLAB SIM but
    doesn't mask the port right.
    THANK YOU. Problem solved
    Wink
    Good news !
    Just for the fun ...
    How many boards saved ???
    Apr 2008
    Berlin, Germany
    uhm .. one
    I'll post the code in the apropriate section when it's done. It's for a Li-Ion Battery Management System (BMS)/Balancer
    Wink
    Hi, Castor
    What is your device for ??? Modelling purposes ?
    By the way, I realized a voltage warning device for transmitters ( for a Nicad to LiPo conversion ), some times ago, and, by the way noticed there's a not negligible tempco with those batts ...
    doesn't simplify the measurements !!!
    Regards from ... an ex Tegel " blue uniform " temporary citizen.
  1. Best way to shut down HPWM channel?
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 26th January 2010, 22:01
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  3. Hserin
    By [email protected] in forum Serial
    Last Post: - 16th December 2008, 18:49
  4. 18F1320 ADC multiple channel select
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 21:40
  5. 16F819 ADCIN Channel Select?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 18:31
