Multiplexer channel selection
Results 1 to 18 of 18
    Wink
    Italics vs. Italics
    Italics vs. [ I ] Italics [ / I ]
    Hi, Ski
    Yes ... Ok, But ALSO inside a CODE window ...???
    could we talk about a BUGGGGGGGGG ????
    I don't know if it's a bug or not. Maybe bbCode doesn't handle nested tokens, or at least that nested token correctly, maybe it was intended to be that way.
    Apr 2008
    Berlin, Germany
    Please stay on topic.
    Here's a summary: I have two pesky devices in my circuit. A multiplexer and a decoder.The multiplexer is connected as:
    MUX
    'RA5	INH
    'RA1	A
    'RA2	B
    'RA3	C
    'RA4	D
    notice how the selection channels are on consecutive pins thus making things easy for selecting the channels:
    'mux channel selection
    'low inh_mux
    'for i= 0 to 15
    '       Porta =  (Porta & %11000001 ) + (i *2)	'port masking for cycle purposes
    'next i
    On the other hand the decoder pins are scattered across PORT B and PORTC:
    'DCD
    'RE2	G1,G2
    'RB7	A
    'RB6	B
    'RB5	C
    'RC6	D
    here's the code i've devised:
    'dcd channel selection
    low g_dcd
    for i=0 to 15
    	portb = (portb & %00011111 ) + (i rev  3)<<5
    	portc = (portc & %10111111 ) + (i<<3)
    next i
    The PORTB pins selection works fine (meaning lines A, B and C of the decoder behave as I expected). But line D (the only one on PORTC) gives me a headache. Am I missing something in the mask ?
    Quote Originally Posted by Castor View Post
    Guess what? Free help! Deal with it.
    low g_dcd
    for i=0 to 15
    	portb = (portb & %00011111 ) | ( ( i rev  3 ) << 5 )
    	portc = (portc & %10111111 ) | ( i << 3 )
    next i
    OR don't ADD
    low g_dcd
    for i=0 to 15
    next i
    OR don't ADD
    to get rid of the i lower bits for portC ...
    i would have used
    portc = (portc & %10111111 ) | ( i.3 << 6 )
    but, it's me ...
    portc = (portc & %10111111 ) | ( i.3 << 6 )[/code]
    I've tried to do something like that before. If I remember right, the fact that i.3 is a bit didn't work well with the << 6. It ended up shifting itself out into nowhere and always ended up being a '0'.
    Maybe that was back in the day, in an older version of PBP or something. It just seems to me like that didn't work very well.
    Wink
    I did at test on the breadboard this morning ...
    Everything fine ...
    Apr 2008
    Berlin, Germany
    This is the winner:
    I've tried both in MPLAB SIM but
    doesn't mask the port right.
    THANK YOU. Problem solved
  1. Best way to shut down HPWM channel?
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 26th January 2010, 22:01
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  3. Hserin
    By [email protected] in forum Serial
    Last Post: - 16th December 2008, 18:49
  4. 18F1320 ADC multiple channel select
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 21:40
  5. 16F819 ADCIN Channel Select?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 18:31
