Multiplexer channel selection
Results 1 to 18 of 18
    Apr 2008
    Berlin, Germany
    Default Multiplexer channel selection
    It's more of a conceptual question then a programming issue. I use a pic to control the inputs of a 16 channel multiplexer, thus allowing me to select a certain channel and read voltages from a multi cell battery pack. How do I inteligently cycle through the mux control inputs other then aliasing ports and attributing values ?
    a_mux	var	porta.1
    b_mux	var	porta.2
    c_mux	var     porta.3
    d_mux	var	porta.4
    inh	var     porta.5
    'select MUX channel X0
    a_mux = 0:b_mux = 0:c_mux =	0:d_mux = 0:inh   = 0
    'select MUX channel X1
    a_mux = 1:b_mux = 0:c_mux =	0:d_mux = 0:inh   = 0
    'select MUX channel X2
    a_mux = 0:b_mux = 1:c_mux =	0:d_mux = 0:inh   = 0
    'select MUX channel X3
    a_mux = 1:b_mux = 1:c_mux =	0:d_mux = 0:inh   = 0
    'and do this up to channel 15
    It would be really useful to cycle using a for.. next loop and I belive it's quite possible because the multiplexer's truth table consists of consecutive binary numbers for the selection inputs. I'm thinking something like:
    i var byte
    a_mux	var	porta.1
    b_mux	var	porta.2
    c_mux	var     porta.3
    d_mux	var	porta.4
    i.7 var a_mux
    i.6 var b_mux
    i.5 var c_mux
    i.4 var d_mux
    for i= 0 to 15      ' meaning i=00000000
                                    00000001
                                    00000010
    ' do stuff
    next i
    But it doesn't compile well because quote "Variable already an alias". How do I get around this ? All the code above is just for demo purposes, I know TRIS is not set and the other stuff that goes into an actual program is missing
    Hello Castor,
    I am not good at them,but I believe you are looking for an ARRAY.
    see:http://www.picbasic.co.uk/forum/showthread.php?t=8486
    http://www.google.com/custom?hl=en&c...picbasic.co.uk
    Wink
    hi,
    your answer is "something like that"
    ... but as the PIC will perform the A/D conversion ... a Porta Analog input has some good chance to be in use ... if you do not use another ADC input ( PortE 0,1 or 2 for a 16F877a )
    without any headaches ... it gives
    Porta.5 = 0                ' Enable the Mpxer
    for I = 0 to 15
     Porta =  (Porta & %11000001 ) + (I *2)  ' Keep Porta.5 low, Porta.0,6,7 as is, and Porta1-4 select the input
     Pause 5                               ' to stabilize Mpxer Output voltage
     ADCin Portx.y, value[I]           ' Portx.y is where the Mpxer output is connected ...
                                               'value[I] is the table location corresponding to the cell
    NEXT I
    too simple !
    PS: May be someone could explain me why writing [] with UPPERCASE I inside the brackets show
    [I]
    skimask's Avatar
    skimask Guest
    [I]
    Italics vs. Italics
    Italics vs. [ I ] Italics [ / I ]
    http://www.phpbb.com/community/faq.php?mode=bbcode
    Wink
    Italics vs. Italics
    Hi, Ski
    Yes ... Ok, But ALSO inside a CODE window ...???
    could we talk about a BUGGGGGGGGG ????
    Apr 2008
    Berlin, Germany
    Hey, thanks for the great answer.
    It works like a charm. In fact I use a 16 bit external A/D converter so using PORTA pins as digital I/O doesn't pose an issue. What if the selection pins are scattered across two ports ? Can I get around that without selecting each and every output manually ? Or reworking the board ? (I didn't quite think about channel selection when I built it)
    'DCD
    'RE2 G1,G2
    'RB7 A
    'RB6 B
    'RB5 C
    'RC6 D
    Quote Originally Posted by Castor View Post
    Why not ...
    you'll have to write two lines for Ports masking instead of one !
    if you have a pot or button available and a free Pic input or two ... you can easily make the manual channel selection "by soft" ...
    but , may be, you'll have to add a small board on the existing one ( in french : une impériale !!! )
    skimask's Avatar
    skimask Guest
    I don't know if it's a bug or not. Maybe bbCode doesn't handle nested tokens, or at least that nested token correctly, maybe it was intended to be that way.
    Apr 2008
    Berlin, Germany
    Please stay on topic.
    Here's a summary: I have two pesky devices in my circuit. A multiplexer and a decoder.The multiplexer is connected as:
    MUX
    'RA5	INH
    'RA1	A
    'RA2	B
    'RA3	C
    'RA4	D
    notice how the selection channels are on consecutive pins thus making things easy for selecting the channels:
    'mux channel selection
    'low inh_mux
    'for i= 0 to 15
    '       Porta =  (Porta & %11000001 ) + (i *2)	'port masking for cycle purposes
    'next i
    On the other hand the decoder pins are scattered across PORT B and PORTC:
    'DCD
    'RE2	G1,G2
    'RB7	A
    'RB6	B
    'RB5	C
    'RC6	D
    here's the code i've devised:
    'dcd channel selection
    low g_dcd
    for i=0 to 15
    	portb = (portb & %00011111 ) + (i rev  3)<<5
    	portc = (portc & %10111111 ) + (i<<3)
    next i
    The PORTB pins selection works fine (meaning lines A, B and C of the decoder behave as I expected). But line D (the only one on PORTC) gives me a headache. Am I missing something in the mask ?
    skimask's Avatar
    skimask Guest
    Guess what? Free help! Deal with it.
    low g_dcd
    for i=0 to 15
    	portb = (portb & %00011111 ) | ( ( i rev  3 ) << 5 )
    	portc = (portc & %10111111 ) | ( i << 3 )
    next i
    OR don't ADD
    low g_dcd
    for i=0 to 15
    next i
    OR don't ADD
    to get rid of the i lower bits for portC ...
    i would have used
    portc = (portc & %10111111 ) | ( i.3 << 6 )
    but, it's me ...
    skimask's Avatar
    skimask Guest
    portc = (portc & %10111111 ) | ( i.3 << 6 )[/code]
    I've tried to do something like that before. If I remember right, the fact that i.3 is a bit didn't work well with the << 6. It ended up shifting itself out into nowhere and always ended up being a '0'.
    Maybe that was back in the day, in an older version of PBP or something. It just seems to me like that didn't work very well.
    Wink
    I did at test on the breadboard this morning ...
    Everything fine ...
    Apr 2008
    Berlin, Germany
    This is the winner:
    I've tried both in MPLAB SIM but
    doesn't mask the port right.
    THANK YOU. Problem solved
    Wink
    Good news !
    Just for the fun ...
    How many boards saved ???
    Apr 2008
    Berlin, Germany
    uhm .. one
    I'll post the code in the apropriate section when it's done. It's for a Li-Ion Battery Management System (BMS)/Balancer
    Wink
    Hi, Castor
    What is your device for ??? Modelling purposes ?
    By the way, I realized a voltage warning device for transmitters ( for a Nicad to LiPo conversion ), some times ago, and, by the way noticed there's a not negligible tempco with those batts ...
    doesn't simplify the measurements !!!
    Regards from ... an ex Tegel " blue uniform " temporary citizen.
    Apr 2008
    Berlin, Germany
    it's for an electric golf cart I'm building
  1. Best way to shut down HPWM channel?
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 26th January 2010, 23:01
  2. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  3. Hserin
    By [email protected] in forum Serial
    Last Post: - 16th December 2008, 19:49
  4. 18F1320 ADC multiple channel select
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th November 2005, 22:40
  5. 16F819 ADCIN Channel Select?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 27th April 2005, 19:31
