18LF4680 on heat
Results 1 to 8 of 8
    Wink
    Just an interesting question ...
    which is applied to the pic first ???
    The Pic 5V
    OR
    The LiPo DIRECT 4.3v ???
    could easily explain the correct operation with a series resistor ...
    coz The clamp diodes surely would not like to power the whole card ...
    just to see ... try to place a 1N400x from A0 input to the +5 v ...
    my two cents ...
    Sep 2003
    Vermont
    Put a 1K resistor in series from the LiPo battery to A.0 PERIOD.It's just safe engineering practice. I don't see a need to post the code, or parse the replies any further.
    I have a button read subroutine that must set the pin to an input before reading it. Something in the program, totally unrelated to that pin, is setting it to an output low. Sound familiar? Now, I can go through every subroutine and watch that line to find out EXACTLY what is tripping the pin to be an output, or I can make sure it is an input before I read it. I choose to set it to a known state before I rely on the test. If it is an output, the reading will be unreliable. I won't lose the chip. In your case, you will. If you have the time, go ahead and see what is causing the problem. Connecting any port directly to B+ is a very bad idea.
    Ron
  1. PIC 12F509 begins to heat at power up
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 13:11
  2. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 03:24
