Time-Lapse
Results 1 to 40 of 43
Thread: Time-Lapse
    Dec 2005
    Quote Originally Posted by Ted's View Post
    Can you help me out here as well, g-hoot?
    Ted's,
    I think I understand this less than you, so don't put too much faith in mu help. I still don't understand what a comparator does?... The idea of checking for high or low is what I like best (cause it's simple), but I guess there can be some issues with in bouncing like skimask mentioned. Maybe you could use a weak pull-up resistor to keep the pin high to prevent the bouncing problem. Or, you could simply cut and paste the RCTime code I posted and be done. ;-) I agree with skimask that all the info is in the data sheet, but I still have a hard time understanding what the data sheet says! They sure aren't written for people that are using PBP! That's why I posted my exact RCTIME code for you. I know to most here, that it is day one basics, but for us new guys, it's like learning a new language, and a little spoon feeding is nice and helps in understanding what's going on. :-)
    Gary
    Ted's's Avatar
    Ted's Guest
    I agree, the manual is not written for people using basic. And on the right site in the pdf manual the pictures of comparator configurations don't show the configuration I need.
    The PIC datasheet and the PBP manual are 2 different worlds, connected by a common purpose...True. It's not like a car owners manual vs. an engine overhaul manual. Agreed. But...PICs ain't cars and cars ain't PICs. And you can't reconfigure a car to haul satellites into orbit.
    As far as the comparator goes...if the right configuration isn't in the datasheet, it probably can't be configured the way you want to be....
    Which is what again? Maybe we can come up with a workaround for ya...
    Dec 2005
    With my wire and duct tape, and your BFH, we can do anything! HA
    I understand your analogy about the car owners manual vs. an engine overhaul manual, and you are right....but, Look at the attched pic for an exaple of what I'm talking about though. When I wanted to use EEPROM, that is the example in the datasheet for my chip. I guess that's assembly language? It don't look anything like that in my program. It almost makes sense in PBP. :-) Would be nice if they offered examples in the common languages. I like stuff like "Read, Write, If, Then" that makes sense. I mean no disrespect. I'm just whining cause I'm a rooky an don't really understand what's under the hood! ;-)
    Gary
    Did anyone read the links up in post#32?
    If you did here is another.
    http://www.melabs.com/resources/samp...p/cmp877Ax.bas
    Maybe you are reading the wrong manual
    http://www.melabs.com/resources/pbpmanual/
    Dec 2005
    I finally did...very good reading and explanation on the comparators. I am going to have to try Melanie's tutorial when I get a chance...very well written and explained! Thanks for those links Dave!
    Gary
    Quote Originally Posted by g-hoot View Post
    If/when you run across stuff from Melanie, save it. Always good instructions.
    That's why RTFM is such a common answer to a lot of problems. PBP handles all that low level eeprom stuff for you.
    You'll find that PBP can handle a lot of low level stuff for a lot of things. And a lot of things that aren't handled by PBP, can more than likely be found on the forums...practically prewritten. Once you get used to it, it's all good..
    And I like twine, duct tape, bubble gum, JB Weld...
    Ted's's Avatar
    Ted's Guest
    ...twine, duct tape, bubble gum...
    Speaking of which I am using Blutak and I do not like this plasticine at all. I think it is disgusting. Unfortunately I have not found another method of connecting the ldr to the cam....
    Ted's's Avatar
    Ted's Guest
    I am using blutak now and a suitable resistor forming the voltage divider. It is working well enough by using a simple I/O-Pin.
    I am proceeding here.
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 14:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
