Time-Lapse
Results 1 to 40 of 43
Thread: Time-Lapse
    FYI g-hoot,
    http://en.wikipedia.org/wiki/Photoresistor
    Now Ted has code for his project too and what speed to expect.
    Dec 2005
    FYI g-hoot,
    Dave,
    Thanks for the link. I think the sentence below may explain why several different cells produce basically the same results:
    "Many commercially available CdS cells have a peak sensitivity in the region of 500nm - 600nm (green light)."
    Gary
    Yeah, that green light thing nailed me a few years ago. Had a project working the way I wanted in the shop and never thought about how sun light has a different spectrum until I took it out side. All of my setting were off.
    Ted's's Avatar
    Ted's Guest
    I like the symbol
    I am going to use a device that looks similar to a CDS cell and a ldr, maybe it is a ldr. It is very flat and it's dimensions are 4mm x 4mm. Do you have an idea on how to keep the LDR on the led even though the camera is moving?
    Dec 2005
    Quote Originally Posted by Ted's View Post
    Well, I'm from OK, so tape is an obvious choice. :-) You could just use some long wires on the light sensor and tape it, or for a more permanent solution, maybe a clear glue on the face of the cell, then glue around the outside with something black to block light out. Black caulking would work. For the clear glue, use GOOP. It sticks to everything, is clear, and peels right off if you need to clean it off later.
    Gary
    Ted's's Avatar
    Ted's Guest
    Question
    What is OK?
    Dec 2005
    Sorry, the abbreviation for the state of Oklahoma in the US. We're kinda rednecks down here. Well at least some of us are. ;-)
    Gary
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 14:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
