changing code from 16F to 18F microprocessor
Results 1 to 14 of 14
    May 2008
    Default midrange chip
    Alain Thanks for the reply. I would like to use the pic16f877 (since I have a few onhand) but I was concerned it would behave similar to the 16f84a that I am currently using.
    I was experiencing a large variation in the incremented variable despite the fact that the time between the sensors was very precise. (I use the raw counts in a flow calculation.) The actual time between the sensors varies from 2 - 5 seconds depending on the flow. The raw counts for the variable (value) are approximately 33,000 for 1 ml/min flow. The variablity was more than 25% between successive measurements and I also observe a decay in the counts.
    I thought a chip with more capacity would help. I realize now that it is a large leap from one to the other since I will have to rewire the processor board to the 18f pinout.
    If there is a chip you could recommend that would meet the data and calculation needs while trimming down the unused peripherals that would be appreciated as well.
    I think the closest to F877 is the 18F452. It is pin to pin compatible and has twice the memory. Once I remember porting the almost 7,5K of program directly to the F452 with a couple of DEFINEs on top. Piece of cake.
    Agreed 100%.
    Started out a project a long time ago on a 16F877A. Ran out of memory, plugged in an 18F452, changed a couple of define's, a few register settings, ran great. Ran out of memory again, plugged in an 18F4620, changed a few more register settings...Same program, ran like a champ (then ran out of code space again, built up an 80pin TQFP-> 40 pin DIP adapter for an 18F8722, plugged it in, changed 1 or 2 register settings, doubled the code space, ran great again).
    Agreed 100%.
    ... then run out of memory again and plugged a ... x86 core 2 with 2gb of memory!
    I could run the 18F8722 in external mode and 2GB of flash....and skip the Core2 altogether
    But that's what I get when I kept adding crap on top of crap on top of crap
    I went thru the code awhile back and tried a fair amount of optimizing. Turns out I could've stuck with the '452 if I'd have just been a bit more diligent in the code writing in the first place.
    I think thats called spaggeti programming! You are lazy to optimize it once then it grows linearly, or better exponentially, full of crap! I 've been there too!
    Quote Originally Posted by SCC_699 View Post
    Hi, You can try the 18F1320 instead of a 16F84 ... pinout is COMPATIBLE ( care ... pins names are not the same !!! ... so you only have to rename them . )
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. 16F to 18F transition pains
    By lurker in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 01:35
  5. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 01:28
