changing code from 16F to 18F microprocessor
Results 1 to 14 of 14
    May 2008
    Default changing code from 16F to 18F microprocessor
    I am relatively new to the chip programming game and I have some of my first code below for your review. I am trying to time some liquid flow between sensors. I found large discrepancies from count to count (value variable). Basically, I see a time decay. I tried resetting the flags for the TMRO counter, to no avail.
    I thought I would try a chip with more memory (current chip is PIC16f84a, new chip is PIC18f2620), but I get a compiler error. I thought the pin assignments were off. I'm sure there are quite a few things I'm missing any help would be appreciated.
    dummy var word ' div 32 variable
    newdum var word
    newdum3 var word
    value var word ' raw counts
    num var word
    den var word
    clear
    input portb.5 'start signal first sensor
    input portb.6 'stop signal second sensor
    input portb.7 'resume
    output portb.0 'solenoid
    high 0
    Pause 500 ' Wait 0.5s for LCD to startup
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Chromatography Inc." 'display message first line
    Lcdout $fe, $c0, "Flow Meter2" ' Display meaasege second line
    pause 4000
    Lcdout "By Helcio" 'display message first line
    Lcdout $fe, $c0, "Ver 1.0" ' Display meaasege second line
    pause 4000
    loop:
    value = 0
    num = 0
    den = 0
    low 0
    Lcdout "Waiting for" 'display message first line
    Lcdout $fe, $c0, "Pump" ' Display meaasege second line
    loop2:
    ' checks for first sensor
    if portb.5 = 1 then loop2 'check start input
    lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Measuring" ' Display message
    loop3:
    'counts while liquid is between sensors
    Pause 1 ' Wait 0.001 second
    value = value + 1 'count time delay
    if value > 60000 then loop5
    if portb.6 = 1 then loop3 'check stop input
    high 0
    if value < 2 then loop6
    'num = value / 1000
    'den = value // 1000
    'Lcdout "t = ", dec num, ".", dec den, "s" ' display time
    Lcdout "t = ", dec value ' display time
    dummy = value * 369 'm value of equation from slope equation y=mx+b
    newdum = div32 1000
    newdum3 = 5441 - newdum 'b value of equation
    num = newdum3 / 1000
    den = newdum3 // 1000
    Lcdout $fe,$c0, "r = ", dec num, ".", dec den, "mL/min" ' ratio time
    loop4:
    if portb.7 = 0 then loop4 'check again input
    goto loop
    loop5:
    Lcdout "Pump to slow"
    Lcdout $fe,$c0, "Increase speed"
    loop7:
    if portb.7 = 0 then loop7 'check again input
    goto loop
    loop6:
    Lcdout "Pump to fast"
    Lcdout $fe,$c0, "Decrease speed"
    loop8:
    if portb.7 = 0 then loop8 'check again input
    goto loop
    Thanks for your help
    Quote Originally Posted by SCC_699 View Post
    Define compiler error better and you might get a bit more help...
    And which version of PBP?
    May 2008
    Default compiler error
    I am using PBP ver 2.47
    the compiler error is "Configuration programming error at 0000"
    Originally compiled with chip PIC16f84a tried to recompile by selecting PIC 18F2620 get the above
    thanks
    Lightbulb You MUST Configure your chip ...
    Hi, The following is ...
    just a simple 18F2520 header !!!
    'Defines
    DEFINE BUTTON_PAUSE 250
    DEFINE ADC_BITS 10
    'DEFINE LCD_COMMANDUS 2000
    'DEFINE LCD_DATAUS 50
    ' Define LCD connections
    DEFINE LCD_DREG PORTC   	' Set LCD Data port
    DEFINE LCD_DBIT 4       	' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB  	' Set LCD Register Select port
    DEFINE LCD_RSBIT 5      	' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB   	' Set LCD Enable port
    DEFINE LCD_EBIT 6      		' Set LCD Enable bit
    DEFINE LCD_BITS 4       	' Set LCD bus size (4 or 8 bits)
    ' Constantes
    ExtOSC 		con 32768		'Quartz Horloge "temps" en Hz
    Tension_ 	con 0			'Correspondance pour Canaux ADC
    TempA_		con 1
    TempH_		con 2
    Dureetonte	con 1		' de -1h à +59 mn ... ( 1/2 durée !!! )
    Kelvin		con 273
    '***************************  seuils Alarmes  ********************************
    AlmVolt		con 15	* 100	'>=		Tension trop élevée			1/100 V
    AlmRpm		con 3600 		'>=		Régime trop élevé			T/Mn
    AlmAir		con 90  + 273	'>=		Temp Air Trop élevée		°K ^ 82
    AlmHuileL	con 0   + 273	'<=		Temp Huile trop basse		°K
    AlmHuileH	con 100 + 273	'>=		Temp Huile trop élevée		°K
    '**************  Periodicités d'Entretien ( ordre croissant ! )  *************
    Service1	con 10 ' Heures
    ServiceV	con 20
    Service2	con 25
    Service3	con 50
    Service4	con 100
    Service5	con 300
    DATA (0),0 (29) 'Raz des Mémoires si reprogrammation
    ' 1er préchargement 22H31M29S
    DATA @0, $1
    DATA @4, $1
    DATA @6, $16 				' 22 Heures
    DATA @10,$1F				' 31 Minutes
    DATA @12,$1D				' 29 Secondes
    DATA @14,$FF
    DATA @16,$0D				' 3583 Tr/mn
    DATA @22,$53				' 83°C Air
    DATA @26,$59				' 89°C Huile
    VERSION		con 1			'N° de la révision
    'Config processeur
    '@  __CONFIG    _CONFIG1L, _WDT_OFF_1L & _WDTPS_128_1L
    @   __CONFIG    _CONFIG1H, _IESO_OFF_1H & _OSC_XT_1H & _FCMEN_OFF_1H
    @	__CONFIG	_CONFIG2L, _BOREN_OFF_2L & _PWRT_ON_2L
    @   __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    '@  __CONFIG    _CONFIG3L, _WDT_OFF_3L & _WDTPS_128_3L
    @   __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_PORTBE_3H
    @   __CONFIG    _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L & _XINST_OFF_4L
    '@  __CONFIG    _CONFIG4H, _WDT_ON_4H & _WDTPS_128_4H
    @   __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    @   __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @   __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    @   __CONFIG    _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
    @   __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    @   __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    'Config TIMERs
    T0CON = %00000010	' 16Bits 1/8 prescaler, Horloge Système, OFF
    					' Utilisé pour détection sous regime ou arret
    T1CON = %00000000	'1/1 prescaler, Quartz 32,768
    ' *** Géré par Elapsed Timer ***
    T3CON = %01110001	' CCP SUR TMR3,1/8 prescaler,Horloge système,ON
    					' Mesure de la vitesse
    'Config CCP1 arret CCP2
    CCP1CON = %00000101	' Capture sur front montant
    CCP2CON = %00000000	'inhibition module CCP2
    'Inhibition SSP
    SSPCON1.5 = 0
    'Inhibition Comparateurs
    CMCON = 7
    'Inhibition Reference interne
    CVRCON = 0
    'Config Interruptions
    INTCON  = %10000000
    INTCON2 = %11110000
    INTCON3 = %00000000
    PIE1    = %00000100
    PIE2    = %00000000
    IPR1    = %00000001
    IPR2	= %00000000
    RCON	= %10000000
    'Config ADC
    ADCON0 = %11000000		'
    ADCON1 = %00011011 		' 3/1
    ADCON2 = %10100110		' Right Just., 8Tad, clock /64
    'Config et Prepositionnement E/S
    PORTA	= %00110000
    PORTB 	= %00010000
    PORTC	= %00001000
    'PORTD	= 0
    'PORTE	= 0
    TRISA 	= %00011111
    TRISB	= %00000110
    TRISC	= %00000111
    'TRISD	= %00000000
    'TRISE	= %00000000
    'Alias E/S
    'MCLR/ sur Broche 1 par R/C/D
    Voltage		var PORTA.0		'TENSION Batterie / 4
    TempA		var PORTA.1		'LM335
    TempH		var PORTA.2		'LM335
    Vref		var PORTA.3		'TL431 = 4.096v ...
    Raz			var PORTA.4		'JUMPER Raz/Programmation
    AlRef		var PORTA.5		'Alimentation référence TL431
    Buzzer		var PORTB.0
    Contact		var PORTB.1		' + 12 v sous clé ( / 4 = 2 - 4 v !!! )
    Selection 	var PORTB.2		'Poussoir sélection Affichage
    Signal		var PORTB.3		'Sortie Survitesse
    AlLCD		var PORTB.4		'Alimentation LCD BS 250 !!! 0 = ON : 1 = OFF
    RS			var PORTB.5
    E			var PORTB.6
    Alm			var PORTB.7		'Sortie Alarme
    '			var PORTC.0		'Qz 32768
    '			var PORTC.1		'   "
    Speed		var PORTC.2		'Entrée compte-tours 1C/4T
    Alim		var PORTC.3		'Autoalimentation
    D4			var PORTC.4
    D5			var PORTC.5
    D6			var PORTC.6
    D7			var PORTC.7
    'Buzzer		var PORTD.0		'Sortie commande Buzzer
    'Signal		var PORTD.1		'Voyant Survitesse
    'RS			var PORTD.2
    'E			var PORTD.3
    'D4			var PORTD.4
    'D5			var PORTD.5
    'D6			var PORTD.6
    'D7			var PORTD.7
    '			var PORTE.0
    '			var PORTE.1
    'AlRef		var PORTE.2
    'Types Variables
    Result		var WORD
    Volt		var WORD
    Tension		var WORD
    Tensionmoy	var WORD
    Tair		var WORD
    TAMax		var WORD		' Valeur Maxi Split
    TairMax		var WORD		' Valeur Maxi mémorisée
    Thuile		var WORD
    THMax		var WORD		' Valeur Maxi Split
    THuileMax	var WORD		' Valeur Maxi mémorisée
    Now, you know what you have to do ...
    hé,hé
    May 2008
    Default 16f different than 18f
    Do I need to define / configure all of the ports on the chip or just the ports used in the program? I don't recall defining the ports that way for the 16f and it seemed to compile fine and run well except for the wide range in the counts from the timer loop.
    Feb 2005
    Kolkata-India
    Default Have you tried with MPASM
    Have you tried with MPASM ? Could you actually locate the "18F2620.INC" . Default configurations are always there. So I seriously doubt why the program would not compile and issue configuration error. Here it does compile okay.
    Sougata
    Wink
    The compiler did it for you ... as your first projects were using the DEFAULT config provided !!!
    For "bigger" chips the compiler DEFAULT config lines are not so numerous as the offered features ... it's you to define what you want !!!
    You, of course, have to define all ports as I or Os , and initialize them ... if you do not want to get unexpected behaviour.
    May be a "midrange" series chip as a second one ( if i understood your post ...) as a 16F628, 16F648 ,16F876a or 16F877a could help for the transition ... with their "limited bunch" ( lol ! ) of peripherals ...
    May 2008
    Default midrange chip
    Alain Thanks for the reply. I would like to use the pic16f877 (since I have a few onhand) but I was concerned it would behave similar to the 16f84a that I am currently using.
    I was experiencing a large variation in the incremented variable despite the fact that the time between the sensors was very precise. (I use the raw counts in a flow calculation.) The actual time between the sensors varies from 2 - 5 seconds depending on the flow. The raw counts for the variable (value) are approximately 33,000 for 1 ml/min flow. The variablity was more than 25% between successive measurements and I also observe a decay in the counts.
    I thought a chip with more capacity would help. I realize now that it is a large leap from one to the other since I will have to rewire the processor board to the 18f pinout.
    If there is a chip you could recommend that would meet the data and calculation needs while trimming down the unused peripherals that would be appreciated as well.
    I think the closest to F877 is the 18F452. It is pin to pin compatible and has twice the memory. Once I remember porting the almost 7,5K of program directly to the F452 with a couple of DEFINEs on top. Piece of cake.
    Hi, You can try the 18F1320 instead of a 16F84 ... pinout is COMPATIBLE ( care ... pins names are not the same !!! ... so you only have to rename them . )
    Agreed 100%.
    Started out a project a long time ago on a 16F877A. Ran out of memory, plugged in an 18F452, changed a couple of define's, a few register settings, ran great. Ran out of memory again, plugged in an 18F4620, changed a few more register settings...Same program, ran like a champ (then ran out of code space again, built up an 80pin TQFP-> 40 pin DIP adapter for an 18F8722, plugged it in, changed 1 or 2 register settings, doubled the code space, ran great again).
    Agreed 100%.
    ... then run out of memory again and plugged a ... x86 core 2 with 2gb of memory!
    I could run the 18F8722 in external mode and 2GB of flash....and skip the Core2 altogether
    But that's what I get when I kept adding crap on top of crap on top of crap
    I went thru the code awhile back and tried a fair amount of optimizing. Turns out I could've stuck with the '452 if I'd have just been a bit more diligent in the code writing in the first place.
    I think thats called spaggeti programming! You are lazy to optimize it once then it grows linearly, or better exponentially, full of crap! I 've been there too!
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. 16F to 18F transition pains
    By lurker in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 01:35
  5. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 01:28
