18LF4680 on heat
Results 1 to 8 of 8
    Mar 2008
    Default 18LF4680 on heat
    I have taken up the project of converting a 16LF877 project to a 18LF4680
    Programming the bootloader works, as does bootloading the program.
    For some strange reason the PIC heats up like crazy when port A0 (which I use for AD conversion) is connected to the battery voltage (LiPo, about 4V). When a series resistor is used, AD works normally. The PIC is driven at 5V
    I have disabled all secondary functions (Voltage reference and comparators).
    Why is port A0 causing this heat up? Shouldn't it be high impedance when defined as AD channel?
    Quote Originally Posted by MadAl View Post
    Sounds to me like your A/D ports aren't set up correctly and/or PortA.0 may be output driven low sucking up current...so maybe your A/D isn't set up quite right. Post some code. Maybe you're missing something...
    Maybe a short between A.0 and another pin (ground) that is driven low... Most likely not MCLR/E.3, likely choice A.1 since it's right there.
    EDIT: Just looked at your other posts... Get a new chip...
    Sep 2003
    Vermont
    Once you can cook small pieces of toast on a PIC, you will have catastrophic failure in short order. This I know from plugging the programming header in wrong. It worked for a while, drawing more current than usual, then quit. I'd suggest replacing it, and never connecting an I/O directly to a B+ line.Put a 1K resistor in series if necessary. If you are running at 3.3 volts and using a LiPo which can be charged to 4.2 volts, You will stress the diodes beyond their limit. If there is internal damage to the gate or protection diodes, it's a bad thing.
    Mar 2008
    "EDIT: Just looked at your other posts... Get a new chip... "
    Are you saying this PIC means trouble?? Should I find a 'safer' alternative? Any suggestions are welcome!!
    I checked for shorts, and no there are none. The PCB is professionally made, not just an experimental setup. And as said, with a series resistor the AD conversion works just fine which would imply the port is set up correctly for the AD.
    After the bootloader is in place in a virgin PIC and hooking up the power, the PIC stays cool. But after uploading the program the heat is on. This would imply the error is indeed in the program, not in the PIC or PCB.
    The program is big (close to 8k on the 16F877) but I could post the register settings, AD conversion part and port setup. Maybe this will shed some light in the matter.
    The PIC power supply is 5V and the voltage on port A0 is anything between 0 and 4.2V (LiPo max.)
    Thanks for the suggestions sofar!
    Feb 2005
    Kolkata-India
    Default Probably indicating that particular chip
    Are you saying this PIC means trouble ?? Should I find a 'safer' alternative? Any suggestions are welcome!!
    All I can say is that a PIC has never let me down and I earn my living out of it. Why don't you run only the A/D part of your program and test it out. Also without the full schematic and code it is really hard to comment.
    Sougata
    No, just that you heated it up once. It's most likely done for...
    I've got cars, tv's, water heaters, and a septic system... All of which have been 'professionally made' and/or installed. Guess what? They've all failed at one time or another...
    Sure does. Something tells me that something in the program is turning off the A/D module, setting the pin back to digital mode and setting it low.
    Wink
    Just an interesting question ...
    which is applied to the pic first ???
    The Pic 5V
    OR
    The LiPo DIRECT 4.3v ???
    could easily explain the correct operation with a series resistor ...
    coz The clamp diodes surely would not like to power the whole card ...
    just to see ... try to place a 1N400x from A0 input to the +5 v ...
    my two cents ...
  1. PIC 12F509 begins to heat at power up
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 13:11
  2. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 03:24
