Unless all
specify that are a beginner to the first arms with picbasic pro
I intezione an engine to move step by step with classical schedina STEP and DIR
and there are successful but when you want to see a given (acceleration) on LCD
the frequency of work decreases paurosamente
Almost as I understood the pic can not 'make girasre the engine and at the same time see a given
and so?
there is' a way around the obstacle?
I thank you for helping me understand you can afford
this and 'what I could do with a 16F877
DEFINE OSC 20
DEFINE  LCD_DREG        PORTD   ' Define LCD connections
DEFINE  LCD_DBIT        4
DEFINE  LCD_RSREG       PORTD
DEFINE  LCD_RSBIT       2
DEFINE  LCD_EREG        PORTD
DEFINE  LCD_EBIT        3
DEFINE LCD_LINES 4
DEFINE LCD_DATAUS 50
VEL  VAR  WORD    ' Velocita''
VELOCITA VAR WORD
ACC VAR WORD            ' Accellerazio/decellerazione
ACCELL VAR WORD
servo1  VAR  PORTC.1 ' Uscita step motore 1
         TRISA = 255     ' Enable first button row
         PORTA = %11111111
        ADCON1 = 7      ' PORTA and PORTE to digital
        Low servo1      ' Servo output low
 READ 0 ,VEL
 'read 1, VELOCITA
  READ 2, ACC
     READ 3, ACCELL
      LCDOut $fe, $80, "VEL =  ", #VEL
      'LCDOut $fe, $c0, "VELOCITA =  ", #VELOCITA
      LCDOut $fe, $94, "ACC =  ", #ACC
      LCDOut $fe, $D4, "ACCELL =  ", #ACCELL
     GOTO MAINLOOP
UNO:
 IF PORTA.0 = 1 THEN
 ACC= ACC+1
 PAUSE 10
 IF PORTA.1 = 1 THEN
 ACC = ACC-1
 PAUSE 10
    Lcdout $fe, 1   ' Clear screen
 WRITE 2, ACC
   IF PORTA.2 = 1 THEN GOTO DUE
 GOTO UNO
 DUE:
   IF PORTA.0 = 1 THEN
 VEL= VEL+1
 PAUSE 10
 IF PORTA.1 = 1 THEN
 VEL = VEL-1
 PAUSE 10
 WRITE 0 , VEL
   IF PORTA.3 = 1 THEN
    GOTO MAINLOOP
   GOTO DUE
Mainloop:
       TRISB = $fe
         PORTB = 1
       IF PORTB.1 = 1 Then
       GoSUB MOTOR
     GOSUB MOTOR2
       IF PORTA.2 = 1 THEN
        LCDOut $fe, $c0, "ENTRATA SETUP "
        PAUSE 1000
        GOTO UNO
        GOTO MAINLOOP
    MOTOR:
    IF VELOCITA < VEL THEN
         VELOCITA = VEL
     servo1 = 1      ' Start servo pulse
        PauseUs VELocita
        servo1 = 0      ' End servo pulse
        PauseUs VELOCITA
          velocita = velocita - 1
       LCDOut $fe, $c0, "VEL ",#VELOCITA
     GOTO MAINLOOP
  MOTOR2:
     IF VELOCITA < (VEL*3)  THEN
        PauseUs VELocita
        PauseUs VELOCITA
         VELOCITA = (VEL * 3)
          LOW SERVO1
      velocita = velocita + 1
     GOTO MAINLOOP
