motor step
Results 1 to 3 of 3
Thread: motor step
    fox_53's Avatar
    fox_53 Guest
    Default motor step
    Unless all
    specify that are a beginner to the first arms with picbasic pro
    I intezione an engine to move step by step with classical schedina STEP and DIR
    and there are successful but when you want to see a given (acceleration) on LCD
    the frequency of work decreases paurosamente
    Almost as I understood the pic can not 'make girasre the engine and at the same time see a given
    and so?
    there is' a way around the obstacle?
    I thank you for helping me understand you can afford
    this and 'what I could do with a 16F877
    DEFINE OSC 20
    DEFINE  LCD_DREG        PORTD   ' Define LCD connections
    DEFINE  LCD_DBIT        4
    DEFINE  LCD_RSREG       PORTD
    DEFINE  LCD_RSBIT       2
    DEFINE  LCD_EREG        PORTD
    DEFINE  LCD_EBIT        3
    DEFINE LCD_LINES 4
    DEFINE LCD_DATAUS 50
    VEL  VAR  WORD    ' Velocita''
    VELOCITA VAR WORD
    ACC VAR WORD            ' Accellerazio/decellerazione
    ACCELL VAR WORD
    servo1  VAR  PORTC.1 ' Uscita step motore 1
             TRISA = 255     ' Enable first button row
             PORTA = %11111111
            ADCON1 = 7      ' PORTA and PORTE to digital
            Low servo1      ' Servo output low
     READ 0 ,VEL
     'read 1, VELOCITA
      READ 2, ACC
         READ 3, ACCELL
          LCDOut $fe, $80, "VEL =  ", #VEL
          'LCDOut $fe, $c0, "VELOCITA =  ", #VELOCITA
          LCDOut $fe, $94, "ACC =  ", #ACC
          LCDOut $fe, $D4, "ACCELL =  ", #ACCELL
         GOTO MAINLOOP
    UNO:
     IF PORTA.0 = 1 THEN
     ACC= ACC+1
     PAUSE 10
     IF PORTA.1 = 1 THEN
     ACC = ACC-1
     PAUSE 10
        Lcdout $fe, 1   ' Clear screen
     WRITE 2, ACC
       IF PORTA.2 = 1 THEN GOTO DUE
     GOTO UNO
     DUE:
       IF PORTA.0 = 1 THEN
     VEL= VEL+1
     PAUSE 10
     IF PORTA.1 = 1 THEN
     VEL = VEL-1
     PAUSE 10
     WRITE 0 , VEL
       IF PORTA.3 = 1 THEN
        GOTO MAINLOOP
       GOTO DUE
    Mainloop:
           TRISB = $fe
             PORTB = 1
           IF PORTB.1 = 1 Then
           GoSUB MOTOR
         GOSUB MOTOR2
           IF PORTA.2 = 1 THEN
            LCDOut $fe, $c0, "ENTRATA SETUP "
            PAUSE 1000
            GOTO UNO
            GOTO MAINLOOP
        MOTOR:
        IF VELOCITA < VEL THEN
             VELOCITA = VEL
         servo1 = 1      ' Start servo pulse
            PauseUs VELocita
            servo1 = 0      ' End servo pulse
            PauseUs VELOCITA
              velocita = velocita - 1
           LCDOut $fe, $c0, "VEL ",#VELOCITA
         GOTO MAINLOOP
      MOTOR2:
         IF VELOCITA < (VEL*3)  THEN
            PauseUs VELocita
            PauseUs VELOCITA
             VELOCITA = (VEL * 3)
              LOW SERVO1
          velocita = velocita + 1
         GOTO MAINLOOP
    Unhappy
    It's quite simple: your LCD needs some time to work ...
    and you can't go against that need of time ...
    GLCD tinkerers just begin to understand that ...
    the "simple" solution : one pic reads and writes WHILE another drives ...
    one "other" solution : use multiplexed 7 segments LEDS ... ( a 4x 16, 20, or 40 display might be funny ... I admit ! )
    Alain-
    I am intrigued by the concept of having a dedicated LCD controller PIC. Then, one would send characters serially from the master PIC to the controller PIC? How much time does it take to send a string of characters, relative to the time waiting on the LCD? Is there a way to measure with a scope to determine when the LCD is done?
    I guess I'm trying to determine the "trade-offs" here.
